02-14-2018
14:57
18:54
02-14-2018
14:57
18:54
i’ve has my fitbit since christmas and it was working fine for the first week and then, as i went back to school, i realised it wasn’t counting my stairs. i know i do more than 10 stairs a day because i have to walk around school but it doesn’t count them. ive tried resetting my device using a computer but it hasn’t changed anything. can anyone help?
02-15-2018 06:26
02-15-2018 06:26
@Marcopolo_003 Welcome to the Fitbit Community! I hope you're doing well! Remember that your tracker will count 1 floor for every 10 ft you climb and should be done in at good pace (not too slowly or it won't be counted). Still I do think you are doing more than this at your school. Try cleaning the back part of your tracker with cotton and rubbing alcohol then use some compressed air at a distance to remove any dust or water from the altimeter's hole (see the picture). Still you can retry the restart by doing the following:
Plug the charging cable to your computer or UL certified wall adapter.
Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Your tracker should start charging.
Press the button for 10 to 12 seconds.
You should see your tracker's firmware version and you can now unplug your tracker.
Let me know how it goes!
02-15-2018 06:26
02-15-2018 06:26
02-15-2018 08:36 - edited 02-15-2018 08:37
thankyou so much @AlvaroFitbit. My fitbit is now counting my stairs more accurately. I cleaned out the altimeter’s hole and it is counting more stairs than before. I haven’t tried it at school yet but I’ll have to see when i go back. Thanks again.
02-15-2018 08:43
02-15-2018 08:43
Glad to hear that @Marcopolo_003 one thing I never see mentioned is that the tracker needs to see that the user is walking before it will look for stairs. Sliding the arm up the railing may prohibit steps from being counted, and then stairs will not be.
02-15-2018 08:47
02-15-2018 08:47
ok thanks @Rich_Laue I’ll try and remember this for when i walk up stairs
02-15-2018 08:56
02-15-2018 08:56
I simply lift my arm slightly off the handrail with the oppisit foot
02-15-2018 09:42
02-15-2018 09:42
ok thank for your help! i really appreciate it @Rich_Laue
02-18-2018 12:50 - edited 02-19-2018 07:46
i recently said that my fitbit wasn’t count my stairs. i was told all the details about how it has to be 10 feet and not to pause when walking etc.
i was also told to clean the altimeter hole and after i did that it worked for the rest of the day perfectly fine. However, the next day, my fitbit returned to how it used to be and it is saying i have 0 stairs counted. i have tried to reset it but is hasn’t changed anything. any help?
02-19-2018 07:57 - edited 02-19-2018 07:58
@Marcopolo_003 sorry to hear that your tracker is still giving you issues. At this point I suggest you let our Support team know about the issues you are having so they can review the details on their system. You will get an email from them so hopefully you will be back on track in no time. Make sure to keep in mind all of @Rich_Laue recommendations.
Keep me posted!
03-11-2018 09:32
03-11-2018 09:32
This did not work for me.
I got my Fitbit Charge 2 on Feb 16, 2018 and it accurately counted the flights of stairs in my home. Three days ago it was intermittent and today it won’t count them at all.
Please help trouble shoot.
03-19-2018 10:26
03-19-2018 10:26
@Slothnot Welcome! It's good that the community is growing! Have you tried the suggestions in my previous post including restarting your tracker and using compressed air? Let me know what have you done.
I look forward to your reply!
02-05-2019 06:20 - edited 02-05-2019 06:27
I have cleaned, reset, removed, re-added, and everything esle posted on these forums and it simply will not track stairs properly. It probably record one of every three flights.
02-05-2019 13:10
02-05-2019 13:10
Hello @Baldwin66, may I ask how high your stairs are? They need to be at least 10 feet before they will be counted as a stair.
02-05-2019 13:24
02-05-2019 13:24
09-21-2020 09:46
09-21-2020 09:46
Yep. These Fitbits are really unreliable. Just went up and down stairs 8 times from the basement to the second floor and gave me credit for two floors. My next fitness tracker will be an Apple as I have an Iphone.
09-21-2020 16:44
09-21-2020 16:44
What was your steps counted while walking up the stairs. No steps counted no stairs will be.
If the arm with the Fitbit slides up the hand rail, it's unlikely that steps will be counted.
Also check the hole for the barometer.
Then try a restart. Or a. Power off.
