06-21-2017
18:59
09:49
06-21-2017
18:59
09:49
I received my Charge 2 today and the screen is not turning on.
The help form suggested I take the battery out for a bit and replace, but I am having trouble figuring out how to get the back off.
Thank you.
06-21-2017 19:55
06-21-2017 19:55
Actually the help card suggests you charge your charge for a couple of hours - sorry to confuse.
Here's a couple of helpful links for you to review while your Charge fills up @murph1313
Thanks for coming here first - be sure to clamp the charger on from the back and with the cutout hole matching up with the action button:
Your Fitbit Charge 2 comes equipped with a rechargeable sealed lithium-polymer battery. Charging fully takes about one to two hours from a USB port.
Charging Instructions
To charge your tracker:
While the tracker charges, you can gently tap it (the screen) to check the battery level.
A fully charged tracker shows a solid battery icon.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
Best Answer02-15-2019 12:08
02-15-2019 12:08
Charge 2 shows to be fully charged but will not light up?
02-19-2019 07:02
02-19-2019 07:02
@Wanwalker Welcome to the Fitbit Community! I hope you're doing well! Sorry to hear that your Charge 2 isn't lighting up. Where do you see the battery status? If it is on the phone then it will show the status of the last time it synced but this may not be true anymore. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.
Let me know how it goes!
