01-03-2019
12:05
20:07
01-03-2019
12:05
20:07
I have a fitbit Charge HR. I've had this for several years and its worked fine.
I have recently re-charged the device, the green lights come on at the back but the screen isnt coming on. I've tried to re-sync to the app, the system can find my device but the four digit code isnt coming on.
Has anyone else had this problem and is there anything I can do to fix my fitbit as I cant really afford to buy another one.
Thanks in advance
Amanda
01-04-2019 00:56
01-04-2019 00:56
In the hope that this is just a software glitch I would try restarting the fitbit by:
Give this a few tries as it's known to not always work.
01-04-2019 02:40
01-04-2019 02:40
Hi, thank you for your suggestion,
I have tried this several times and nothing is coming up on my screen.
I think it must be broken ☹️
Best Answer01-04-2019 02:41
01-04-2019 02:41
I think it must be broken.
Thanks though
Best Answer01-04-2019 05:10
01-04-2019 05:10
It doesn't sound good. Even though you will be out of warranty it's still worth contacting customer support via contact.fitbit.com to see if they can fix it or help in any way.
Best Answer01-04-2019 05:15
01-04-2019 05:15
Ok thanks, i will try contacting them to see what they say.
Thanks
Amanda
