03-08-2017
15:48
09:49
03-08-2017
15:48
09:49
After having my charge two for a week, the part of the band that attaches to the actual Fitbit broke. I got a new one, but it broke in the exact same exact spot. Would my warranty still cover another one since I just got it replaced? And what can I do to stop this from happening? It hasn't even been a month since I've purchased it and only seems to last a week before the wristband breaks.
01-20-2018 17:49
01-20-2018 17:49
01-20-2018 18:24
01-20-2018 18:24
01-20-2018 18:26
01-20-2018 18:26
01-20-2018 19:28
01-20-2018 19:28
How long has it held up
01-20-2018 19:50
01-20-2018 19:50
01-21-2018 01:23
01-21-2018 01:23
01-21-2018 04:52
01-21-2018 04:52
01-21-2018 09:01
01-21-2018 09:01
01-21-2018 11:19
01-21-2018 11:19
01-22-2018 16:05
01-22-2018 16:05
Hello Everyone !
Thank you everyone for sharing your experience in the forums, it definitely helps Fitbit to receive feedback from the customers and helps guide the future développement of our products.
To help keep the bands in the best conditions I would always recommend to check on wear and care tips.
Trying out wristbands of different materials seems to be working out pretty well for many of you as well and this could be a good alternative.
@Anniemar, @Jts55, @cyrian I have gone ahead and notified Fitbit Support about your situations since your trackers are without wristbands at the moment. They will be able to check what options they have to help you as best they can !
Also if any of you need any further assistance please let us know !
01-22-2018 20:10
01-22-2018 20:10
02-07-2018 04:26
02-07-2018 04:26
Mine are small too............maybe that is the issue. i dont know. this is my 2nd band to break in one year.
02-07-2018 04:27
02-07-2018 04:27
Mine are small too............maybe that is the issue. i don't know. this is my 2nd band to break in one year.
02-07-2018 18:17
02-07-2018 18:17
02-08-2018 04:48
02-08-2018 04:48
02-08-2018 08:26
02-08-2018 08:26
02-08-2018 16:55
02-08-2018 16:55
02-10-2018 15:54
02-10-2018 15:54
Have a look at this option for a band I have one and it works great.
02-10-2018 21:04
02-10-2018 21:04
wrote:Mine are small too............maybe that is the issue. i don't know. this is my 2nd band to break in one year.
@Missy111 if at least one finger can not easily slip under the band, yes it is to tight.
02-10-2018 21:43
02-10-2018 21:43
