03-08-2017
15:48
09:49
03-08-2017
15:48
09:49
After having my charge two for a week, the part of the band that attaches to the actual Fitbit broke. I got a new one, but it broke in the exact same exact spot. Would my warranty still cover another one since I just got it replaced? And what can I do to stop this from happening? It hasn't even been a month since I've purchased it and only seems to last a week before the wristband breaks.
07-26-2018 10:49
07-26-2018 10:49
Mine too. I managed to have them replace the band 3 times, twice in warranty and once out, but now that I need another one they basically said too bad, so sad. I will be looking into garmin or another device as I am not going to be buying new bands at $40 each every 6 or so months.
08-23-2018 05:03
08-23-2018 05:03
Did not realize they were warrantied. Received first one as gift. Band broke at wrist within months. Ended up using a rubberband to keep on until throwing in a drawer. Bought new rose gold and same spot comes apart. Same exact as previous. Exactly same as daughter- in-law experienced as well. And after asking others, this seemed to be a common occurrence!! I believe it is a design flaw. It has to do with the metal clip at the top of the face. You can put the band back into position but it is most definitely NOT secure and falls off if you breathe on it. In that the Fitbit proved to my doctors that I was not exaggerating at all about not sleeping (averaged less than 3 hours for months due to misdiagnosed lingering stroke damage). I nearly bought the apple watch last time... maybe I should have!!
08-23-2018 13:09
08-23-2018 13:09
@Disfitbut when the band is attached to the tracker, the user should feel and hear a difinite click. If the click is not heard then the tracker is not connected.
Considering how cheap t he after market bands are, the ones with the metalmetal rock, mist friends have multiple bands.
08-23-2018 17:10
08-23-2018 17:10
11-07-2018 06:21
11-07-2018 06:21
I will NEVER buy another piece of CRAP FITBIT and I tell EVERYONE THIS. I am disgusted with it. My strap broke just a few months after purchasing for both that I bought. I ended up supergluing it and that worked for another couple months. Now I have it TAPED which looks like absolute CRAP but it is still functioning. I bought this second one THIS PAST APRIL. **ahem** if it didn’t break exactly like the first only a few months later!!! FITBIT= PIECE OF CRAP
11-07-2018 06:43
11-07-2018 06:43
11-07-2018 06:49
11-07-2018 06:49
You paid to much @summershade I bought the same band for 8.99 aft Target, I also like it.
I find it interesting that many Charge 2 owners have bands that last 1.5 - 2 years and this is reasonable considering that it is just a couple prove of soft silicone. While a few users go through 3-4 bands in a year.
11-23-2018 12:06
11-23-2018 12:06
Thank you for your suggestion of other replacement bands. I too am disappointed FitBit does not care to fix an obvious manufacturing defect because the wrist band keeps breaking within six months, and I am on my third band. But the tracker works great so I was happy to find a reasonably-priced replacement band on Amazon.com.
@summershade wrote:
The metal magnet wrist band offered on Amazon is AMAZING! I paid $9.99 and it is beautiful, sturdy and much easier to wear and slip on and off. I wouldn’t pay a dime for another FitBit band!
12-26-2018 12:44
12-26-2018 12:44
i am having the same problem. The last replacement band sent to me is defective and will not attach. i didn't realize the replacement only has a 30 day warranty so I did not try it before the 30 days. It will not attach to the device. I am done with fitbit. There are many other trackers available today.
12-26-2018 14:49
12-26-2018 14:49
12-26-2018 20:57
12-26-2018 20:57
12-27-2018 02:30
12-27-2018 02:30
12-27-2018 04:41
12-27-2018 04:41
12-27-2018 05:24
12-27-2018 05:24
12-27-2018 08:56
12-27-2018 08:56
12-27-2018 12:02
12-27-2018 12:02
After my third band broke, I switched to buying the metallic one with a magnet that allows for perfect fit and easy adjustment when working out. It is also easier to keep clean if you apply sunscreen regularly to your arms. No more broken bands since then.
12-28-2018 04:01
12-28-2018 04:01
01-21-2019 07:02
01-21-2019 07:02
The problem is with people like me, whose wrists are very slim. Eventually the clasp bends too much because it sharp bend and the end of the device around a slim wrist. It had my fitbit a few years and actually lost one because of this issue, but I found there are some good replacement straps that do a much better job and bend more freely. Worth investing in those if you dont want to loose your fitbit.
01-21-2019 07:27
01-21-2019 07:27
01-21-2019 07:38
01-21-2019 07:38
This is clearly a problem for many people. Here is a link to the watch band replacement that works for me. I bought it a year ago and it's working perfect. Wish I have found it sooner. Good Luck!
https://www.amazon.com/gp/product/B01M0WNQ95/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
