Need new charge hr charging cable
Found my charge hr I bout two years ago.   Can I buy a Walmart charger and still be compatible?
4 REPLIES 4
found my Fitbit after two years missing from a move...  can I buy the charger that Walmart sells?   Is it compatible?  It’s the charge HR.   First generation I guess ...  thanks
I non certified charger could ruin your device. Your best bet is to get a fitbit one. They do have then on Amazon
Community Council Member
Wendy | CA | Moto G6 Android
There is not need to post in multiple forums
@Lizblack I have no experience with that charger but I do not see why it wouldnt work.  Generic chargers should be fine....I do not know if your two year old ChargeHR will still be able to take a charge as batteries will age even if not used.  But its worth a try....good luck.
