Need to update time and date on Charge 2
How do I reset to e and calender on charge 2
I need help resetting clock and date to current date and time. There is no icon on top right corner
6 REPLIES 6
Your tracker's time is set automatically when you sync with your device.  There is no way to set it manually.
@Lup1959 A warm welcome to our Community! Like @SunsetRunner explained you can't manually enter the time and date on your Charge 2. You will need to sync it so it gets the information from your phone or computer. You can manually select the timezone by either changing it on the website or tapping the account button on the Fitbit app (top right corner) then tap Advance Setting where you will find the timezone settings. After this sync your tracker to update the time.
Let me know how it goes!
Alvaro | Community Moderator
I can’t find where to sync
Need to update date and time von Charge 2
Me, neither. I have no FitBit icon on my iMac anymore, either. help! Therefore, I cannot synch at all...
I don't see a free FitBit app on my iMac's App Store's laundry list. Just 2 available to purchase. 2 at 1.99 and poorly rated and one at 3.99. Has FitBit stopped their free support in the past year or so? I haven't used mine in that long. Thanks!
