07-29-2019
22:21
14:11
07-29-2019
22:21
14:11
Just bought new charge 2. The battery worked for one week perfect and now it dies in an hour. This is my second one. First one was bombproof. Never had a problem until it went in the water. Tried resetting, it charges fast and then dies fast.
07-30-2019
10:24
08:09
07-30-2019
10:24
08:09
@Robomower, a warm welcome to our Community!
Let me help you with your Charge 2 battery draining quickly. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
Best Answer07-30-2019 12:30
07-30-2019 12:30
