11-02-2021
18:37
07:07
AndreaFitbit
11-02-2021
18:37
07:07
AndreaFitbit
My brand new Charge 2 won’t charge. What do I need to do?
sn x0030xzi75
16A0CA2C9CCA
Used the charge cable provided with the unit
tried different USB PORTS
my older charge cable
now what?
Moderator edit: format.
11-02-2021 19:28
11-02-2021 19:28
Hi @Philblas brand new? The Charge 2 was discontinued early 2019, so it would have an old battery. When these devices are left unused, the batteries do tend to die. You should check with the seller to see if you can return or exchange it.
11-04-2021 07:13
11-04-2021 07:13
Welcome to the Fitbit Community, @Philblas. Thank you for mentioning the steps you have followed in order to charge your new Charge 2.
As @Odyssey13 mentioned, Charge 2 was discontinued on 2019. Try these steps and if they don't work check with the seller:
Keep on visiting the forums.
