09-26-2016 09:30 - last edited on 09-09-2020 10:26 by MatthewFitbit
10-17-2016 08:56
10-17-2016 08:56
10-17-2016 09:46
10-17-2016 09:46
@FloraTerra have you tried restarting the BT on the Mac? It could be that the fitbit drivers are not responding.
@Eliciab it could be that your phone is to close, within 50 feet, and the Blaze is still connected to the phone. This would prevent the tablet from connecting, try turning the BT off on the phone.
@HD3 I'm not sure what your trying to sync through, but the software is now able to use the generic Bluetooth found in a pc or a standard by dongle. The blaze is also able to sync to most computers through its charging cordwhile connected to the computer
10-17-2016 11:44
10-17-2016 11:44
I still have had no success in trying to pair my new Charge 2 with my computer. Yes, I have turned off bluetooth by shutting down and restarting my Mac desktop several times. I have also tried installing and uninstalling the fitbit software several times as well as resetting the tracker by turning off and on several times. Still getting the same message to turn on Bluetooth even tho Bluetooth is on and working with my wireless keyboard and mouse. I also tried doing this on a different computer, my Mac laptop, and again could not finish pairing the tracker because the same screen popped up about turning on Bluetooth.
10-17-2016 13:50
10-17-2016 13:50
@FloraTerra It might be worth double checking to see if your Mac desktop has Bluetooth 4.0 LE, which is a requirement for both syncing and setting up Fitbit trackers.
I'd also recommend the following steps:
1. Restart your Charge 2.
2. Make sure that you are using the most current version of Fitbit Connect, version 2.0.1.6809.
3. Reboot your Mac.
4. Use the replacement setup process to pair your Charge 2 to your already-existing Fitbit account.
Hope this helps!
10-17-2016 14:51
10-17-2016 14:51
If you're having a hard time getting your device to sync AND you had another device previously, this may help:
Even though you have deleted your old device from the phone app, IT MAY STILL BE PAIRED. I had this happen and it was not only preventing my new device from pairing correctly but also would not let the person who "inherited" my old one pair it to his phone!
Now you should have an easier time of pairing your new device and handing off your old one!
10-17-2016 15:14
10-17-2016 15:14
thank you all....i did call Fit Bits help line and he magically got it working ....need no more help thanks!
10-18-2016 06:23
10-18-2016 06:23
Hey hey hey @Annabel398, Thank you so much for those instructions, very useful because some people just remove the device from the account and then they have issues to pair it again, so I appreciate you have specified to forget the device from the phone's Bluetooth as well.
@HD3, I appreciate you have taken the time to contact Fitbit Support. They always find out the way to help out our users and offer any alternative solution to get them back on track.
If you need more help, keep me posted!
10-18-2016 23:48
10-18-2016 23:48
@HeydyF having same problem as @Spunkylupe12 .
New Charge 2, trying to set up on pc. Asking for dongle. Comes with a usb connector that has clasp cliping into Charge 2. Unable to "connect" using the standard usb connection it comes with. Unable to pick up on bluetooth for ipad as we don't have a "dongle".
Surely there's an easy way to connect new Charge 2 using the box of goodies it came with? Can't remember same problem with new Surge.
10-18-2016 23:54 - edited 10-18-2016 23:59
@Gidg we too are stuck with same problem.... sort of. Doing setup on pc keeps asking to connect "dongle". We have plugged in the usb charge clasp that comes in box (to pc). It doesn't connect though, set up screen just sits there and says "plug in a dongle".... Charge 2 screen just says same "fitbit.com/setup". Can't turn off or do anything. Unable to pick it up on bluetooth with any other device...
How'd you go - get a solution?
10-19-2016 07:34
10-19-2016 07:34
Hey @Magoo2006, it is great to see you around! So you are getting this error when you try to set it up your Fitbit with your PC, right? Could you please tell me which type of computer you are using? 'cause if you are using a PC without Bluetooth, you will need the Dongle in order to set it up your Charge 2 or any other tracker. Now, regarding the iPad you mentioned that you are using, can you please tell me which iPad model you are using? 'cause the "fitbit.com/setup" message appears when you are trying to set it up/sync your tracker with a non compatible device. So get back to me with those answers and I'll be glad to help you out!
I'll be around!
10-19-2016 19:13
10-19-2016 19:13
10-20-2016 06:49 - edited 10-21-2016 09:03
Hi @Spunkylupe12 welcome to the Community. It's great to hear that. To sync with your Mac computer you'll need the USB Dongle. I recommend you contacting support, explain the situation with the Charge 2 and they'll be glad to assist you.
Let me know about the outcome!
Parliamo di calcio Qual è la tua squadra di calcio preferita?
.10-21-2016 17:20
10-21-2016 17:20
I spoke to customer support yesterday, went through all of the troubleshooting tips again and opened a case. Then last night of course I had the same syncing issue. So this morning I called and they are shipping me a new unit. The one thing that impresses me about Fitbit support is they are not stingy when it comes to replacing defective uints!
10-23-2016 04:56
10-23-2016 04:56
Hi moderator - could you confirm that the Charge 2 is not compatible with a Samsung Galaxy S7? And if this is correct - how am I to use my new Fitbit?
10-24-2016 05:58
10-24-2016 05:58
Hi @Gidg, it is great to see you around the Community! I appreciate the update about getting a replacement. I knew that Fitbit Support will help you out with this, as they always do. No matter what is the situation, they always try to find any alternative solution.
@MarGLo, welcome to the Community my friend! The Samsung Galaxy S7 and the S7 Edge are on the list of compatible devices, which means that you can use your Charge 2 with any of them, which means you can set it up/ sync and use the different features as call, text and calendar events notifications. So in order to start, I suggest you to take a look of this post which has instructions to set it up your Charge 2 with an Android device. One you complete that, you can start using your tracker, and if you have questions regarding how to use the other features, let me know!
I'll be around!
10-25-2016 05:35
10-25-2016 05:35
Hi @MarGLo as @HeydyF said, the Samsung Galaxy S7 and S7 Edge have been recently added to the list of the compatible devices to sync. It has all the requirements and more to take advantage of all the Fitbit features
Let me know if you have any other question.
.10-25-2016 06:20
10-25-2016 06:20
11-05-2016 09:09
11-05-2016 09:09
Hi @MarGLo what troubleshooting steps have you tried so far? I recommend you following the steps on this post and on this post for fixing all syncing issues.
.12-02-2016 19:37
12-02-2016 19:37
I am having the same trouble daily. It's so frustrating
12-03-2016 13:12
12-03-2016 13:12
MarGlo, this may not have anything to do with your issue, but if your Fiotbit also has a short battery life, I may know the reason. One of the things I learned the hard way with my Charge HR was that I could not have the computer and the mobile phone app both syncing to the fitbit. It completely drained my battery REALLY FAST. I complained and complained to fitbit not knowing that it was the double hit the fitbit was taking trying to sync with both that was causing it. It may have something to do with your syncing issue as well.
