09-26-2016
09:30
10:26
09-26-2016
09:30
10:26
03-13-2017 10:12
03-13-2017 10:12
Did it---no go!
03-14-2017 03:39
03-14-2017 03:39
I have tried what you suggested about resetting to track sleep and it is still not working to track my sleep.
03-20-2017 19:21
03-20-2017 19:21
I have been syncing my tracker on my charge2 for months. All of a sudden my tracker doesn't sync with my mobile phone.
Not sure why it won't sync. It does sync to my desktop but says it can't find my tracker on my cell. I have deleted my app and re-installed on my phone. I have turned off my Bluetooth and tracker and turned back on.
03-20-2017 19:30
03-20-2017 19:30
Thus us a little confusing, the title says that your unable to setup a new Tracker @arlene, but you say you have had it for months.
Have you shutdown your phone yet?
Your tracker can't be turned off, have you done a restart yet?, http://help.fitbit.com/?q=restart
Also go into the phones Bluetooth settings and tell it to forget/remove the Charge 2
Now try and sync
03-20-2017 19:57
03-20-2017 19:57
03-20-2017 21:14
03-20-2017 21:14
03-21-2017 08:58
03-21-2017 08:58
03-31-2017 09:41
03-31-2017 09:41
Hi my fitbit charge 2 froze yesterday with ! on the screen.
I have followed the instructions you gave for restarting it. The fitbit logo comes on momentarily and then it freezes again with ! on the screen. I cannot get it to restart. Please help.
04-06-2017 11:35
04-06-2017 11:35
It still will not sync. Says, in the android app, "no tracker found". Help!
04-06-2017 11:49
04-06-2017 11:49
Nothing works. Did restart of device on charger holding button down 4+ seconds. Removed device from app. Tried to set up a device, but it fails to connect, after restarting app, restarting Charge 2, turning Bluetooth off and on again, seems that Bluetooth on Charge 2 has stopped working. Now what??
04-12-2017 19:27
04-12-2017 19:27
I purchased my Charge 2 about five months ago and am very disappointed with its functionality. It does not track my heart rate while working out and sleep tracking goes out at least 3 times a month. I am fed up and might start looking for a better and more reliable product
05-10-2017 21:50
05-10-2017 21:50
Did the restart, checked the altimeter hole for dust, still can't get it to count floors. It worked until a week ago & hasn't counted a floor since. Suggestions? Thank you.
05-21-2017 19:21
05-21-2017 19:21
In my experience, the Fitbit and Samsung products are not super reliably compatible. I have a Samsung Galaxy Tab 4 and most of the time I have to sync with one of my other devices because the Samsung will just keep telling me it can't find my tracker. I have an older Kindle and a newer Kindle and both sync just fine with both of my Fitbit trackers. I have the Charge2 as well as an older Fitbit Flex and it's the same with both of them.
05-22-2017 02:21
05-22-2017 02:21
I've never owned a Fitbit without owning a Samson phone.
Galaxy S3,S4,S5, my neighbor has an S6 snd his wife has an S7, none of us can remember the last time we had to restart a phone or tracker to get tge two to sync. For me it was in or before November 2016.
05-22-2017 08:29
05-22-2017 08:29
Syncs just fine with my Samsung Galaxy Tab S2 but refuses to be found by my Samsung Galaxy S6 Edge+.Have tried everything. Any further suggestions? .
05-22-2017 08:30
05-22-2017 08:30
What is your experience with the new one?
05-22-2017 12:53
05-22-2017 12:53
@Stevehg aince it syncs with the Tablet have you made sure the tablet is nit bonded to your travker before trying the S6?
Make sure the tablet us at least 30 + feet away or it's turned off.
07-25-2017 06:48
07-25-2017 06:48
Thank you!!! Thank you!!
After 3 frustrating "Help" days, you solved the problem.
08-03-2017 14:11
08-03-2017 14:11
I have purchased 2 fitbits charge 2 and can't get either of them to charge. When I plug them in I get a slight vibration but no charging icon, instead I have a phone symbol with a scrolling message about going to Fitbit .com/setup. Which I have done, and installed multiple times. If I hold the button down for 3 seconds nothing happens. I am ready to return these and find something else. I am using a Samsung 8s phone to try and link it too.
08-03-2017 14:23
08-03-2017 14:23
@Lefty713, tlyour describing exactly what you should be noticing. The vibration is telling you that the tracker is charging. The setu0 message is telling you the page to go to using the device tyat you want to sync trough. This page will direct you to the proper software that is needed to setup and sync your tracker.
.once your tracker is setup you will see tye charging icon.
