Nickel allergy
I have a nickel allergy and can’t wear my Fitbit anymore . It’s not the strap but the actual face that gives me a rash. Any advice please ?
5 REPLIES 5
Sure about this premise?
Aria, Charge 5, and Xiaomi Mi A2 Lite (Android One) user.
My daughter also has a nickel allergy & got a bad rash from the fitbit Sense I bought for her. We fixed it by putting a screen protector on the back of it (where it touches the skin). I pre-punched 4 small holes for the charger to be able to still connect and had to trim it a little so it didn't cover the band attachment. She's been wearing it now for several weeks with no problems at all. I purchased the ZAGG InvisibleSheild Ultra Clear Screen Protector that fits the Versa2,3, & Sense. It was about $15. Hope this may help you and any others out there with nickel allergies 🙂
Hi y'all! In another post today, I was asked how I made the holes in the screen protector & what tools I used so I thought I'd post the reply here too.
________________________
I used the zagg invisiblesheild screen protector installed on the back of the watch.
https://www.bestbuy.com/site/searchpage.jsp?st=fitbit+sense+screen+protector&_dyncharset=UTF-8&_dynS...
 Step 1 of installation is to remove paper backing & align. After this step I marked the 4 holes (used a thin point Sharpie marker) and trimmed the edges where the band connects (it is a bit long otherwise.)
Then I used a hole punch (picked mine up at Walmart, a whole set of them for around $10 - any hardware store should have them)
Here's a pic of hole punches:
https://www.menards.com/main/tools/hand-tools/punches-nail-sets/wilde-tool-reg-pin-punch-set-5-piece...
Pick the correct size hole punch, set screen protector on a scrap block of wood (or something you don't care about wrecking as it will go through the screen protector & cut into whatever is underneath it), put hole punch on mark and hit with hammer.
Here is a video of someone using a hole punch on leather (start video at 3:53 mark)(In the video he turns his leather piece over & punches it again. You only need to do it from 1 side on the screen protector unless it didn't go all the way through from the 1st hit.)
https://m.youtube.com/watch?v=zcVPrtojVFg
Then finish the installation instructions for the screen protector. It has lasted on my daughters fitbit sense for over 8 months now with no nickel reaction & the charging ports work just fine with no issues.
Hope this helps!😊
Let me know if you have anymore questions.
Hey guys and gals! Today I have a quick Tips & Tricks video, that will show you how to punch perfectly sized holes for installing your leather hardware. Like, Comment, & Subscribe! Follow me on social media: Facebook: https://www.facebook.com/MichaelMaysLeatherworks Instagram: ...
I love you!! Thank you sm!!! I had the exact same idea about the screen protector! I just didn't know how to cut the holes lol.
Glad 2 b able 2 help💖
