04-10-2019
05:42
16:45
04-10-2019
05:42
16:45
I like that the display automatically wakes up when you move your wrist as it presumes you want to see what time it is. However, I’m sure many people have experienced that the display will also wake up in the middle of the night when you roll over and it might have the side effect of waking YOU or your spouse up.
A suggestion for a firmware patch: perhaps make it that when you’ve obviously been sleeping (or you are in your sleep target range), the display only wakes up with a button press? It could be optional in the settings, but I’ve found a few times this would have been an awesome feature.
Perhaps for the Charge 3 it could be a tap instead of a button press, but for those with a 2 we might as well use the side button.
Thoughts and comments welcome!
thanks
04-10-2019 23:33 - edited 04-10-2019 23:40
Hi @bjbNYC Welcome to the Community, nice to see you around, I found this existing suggestion over on the Feature Suggestion Board which shows under consideration and would suggest adding your vote and comments to it too.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
