10-14-2017
13:50
09:26
10-14-2017
13:50
09:26
It seems that the Friday 13th curse has struck my Fitbit again! Last time, on my Charge hr literally fell to pieces. This time my bluetooth has stopped working. I have followed all the help advice of updating, turning bluetooth and off, phone on and off, app on and off to no avail. Fitbit is fully charged.
I even set up the app on my husband's phone but neither app can detect my fitbit. Moreover, when I check on Bluetooth devices able to be detected on each phone, neither can see it. It hasn't synced for nearly 2 days now 😞
Help!
10-14-2017 14:59
10-14-2017 14:59
Unless you enable notifications in the app, your tracker will never show in your phone's settings. Simple syncing only connects via bluetooth during the sync.
10-14-2017 16:06
10-14-2017 16:06
Already done that 😞 Location enabled too.
10-26-2017 08:18
10-26-2017 08:18
@Cadibel Welcome to the Fitbit Community! I hope you're doing well! Try restarting your tracker by doing the following:
Plug the charging cable to your computer or UL certified wall adapter.
Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Your tracker should start charging.
Press the button for 10 to 12 seconds.
You should see your tracker's firmware version and you can now unplug your tracker.
After this restart your phone and remove the tracker from the bluetooth list now go to the app and retry syncing them.
@SunsetRunner thank you for your help in this thread.
Let me know how it goes!
10-26-2017
23:52
10:10
MarlenS
10-26-2017
23:52
10:10
MarlenS
so many post about bt there in Fitbit must know the device has a problem
Moderator edit: format.
Best Answer10-27-2017 00:36
10-27-2017 00:36
Ate you having a problem that we could help with @peterpeg.
As for Bluetooth problems, most have simply been caused by the user not understanding how it works with Fitbut.
10-27-2017 03:53
10-27-2017 03:53
This worked for me! Thank you!
Best Answer10-27-2017 12:14
10-27-2017 12:14
Best Answer02-14-2019 13:19
02-14-2019 13:19
02-19-2019 07:03
02-19-2019 07:03
@mugrat51 Welcome to the Fitbit Community! It's great to have you here! Sorry to hear that your Charge 2 wasn't syncing. Really happy that the instructions worked for you and that you took the time to post and confirm this works. This confirmation may help other members in the same situation.
I'll be around!
