05-27-2020
09:51
09:30
05-27-2020
09:51
09:30
A few days ago my charge 2 started giving me these crazy dashes scrolling up and down instead of the normal data. I synced with the app and it quit for a while before starting again. This happened a couple of times. Now the screen is completely black but it seems to still be working because it's collecting data and syncing with the app. I tried connecting to my charger and resetting by holding the button down. I get a quick vibration but the screen is still blank.
Thanks,
Ravena
05-27-2020 09:57 - edited 06-02-2020 13:36
My screen also went blank a couple of days ago, although it continues to record and sync. I would like to know if there is a way to fix this. 6/2 update - And now, a few days later, it holds a charge for only about 6 hours. I would like to get a response to see if there is a warranty on that. Tried the chat and it wasn't responding
05-28-2020 10:07
05-28-2020 10:07
They responded but weren't helpful, just asked if it was tracking data and that I should try resetting it. Which is what I had already said. *sigh*. I told them again that it was and I'd already tried resetting, I'll let you know what they say from there.
05-29-2020 12:30
05-29-2020 12:30
Now it's completely dead. Nothing can be seen on the screen and the green lights are off. Can someone please help us with this issue? It's been a couple of days and the only response I got was for someone else.
I've tried resetting it again as was recommended but now I get no response.
Thank you,
Ravena
