10-03-2020
05:22
17:52
EdsonFitbit
10-03-2020
05:22
17:52
EdsonFitbit
My Charge 3 connects with my Android phone for running. Use it 2-3 times a week. No problems. Until 3 weeks ago it worked fine for biking. Now it won't connect anymore to GPS when biking is selected. How do I solve this problem? Already reinstalled the fitbit app on my phone.
Thanks
Tremalzo
10-13-2020 14:40
10-13-2020 14:40
Thanks for the update @tremalzo.
On this case, please perform a long restart to your Charge 3:
In addition, please try to log out from the Fitbit app, reboot your cellphone and log back in.
Whether none of this works, please make sure that your cellphone is part of the list of compatible devices. If it is not listed, you might be able to sync and receive notifications but we won't be able to guarantee that everything will work as intended.
Please let us know if you have any question.
Best Answer10-06-2020 17:52
10-06-2020 17:52
Welcome to the Fitbit Community @tremalzo.
I'm sorry to hear that you are having difficulties with GPS connection during your biking activities. Thank you for the information provided and for trying to resolve the issue before contacting us.
If you haven't done it already, please restart your Fitbit Charge 3 by following these steps. In addition, please disable and reenable the GPS feature for biking from your Fitbit account. You can find this option if you go online to fitbit.com > Settings > Devices > GPS.
Whether you continue experiencing the same problem, you can set up your Tracker as a replacement device:
Please make sure you are following our instructions to use the GPS feature.
If you have any question, please let us know.
Best Answer10-10-2020 02:39
10-10-2020 02:39
Hi EdsonFitbit,
Thanks. But it didn’t solve my problem. Only made it worse as I lost GPS connection for running too. Used it this morning for a 2 hour run. it worked fine then. Then I did the suggested fix and lost the GPS connection. Please advise what to do.
thanks,
Tremalzo
Best Answer10-13-2020 14:40
10-13-2020 14:40
Best Answer10-21-2020 07:41 - edited 10-21-2020 07:42
Hi EdsonFitbit,
Did as suggested. This fix works. GPS works fine again for hike, run and bike.
thanks,
Tremalzo
10-27-2020 19:12
10-27-2020 19:12
Thanks for your response @tremalzo.
I'm glad to hear that you've been able to resolve the issue you were experiencing with the GPS connection.
On another note, you are welcome to visit the Health & Wellness board to talk with other members about health and fitness.
Feel free to contact us back at any time if you have any question.
