01-25-2022
03:20
15:46
01-25-2022
03:20
15:46
<span;>Hi there,
<span;>My Charger4 doesn't show any display.
<span;>When I press the button a humming sounds/vibrating starts.
<span;>While I plugged it in to charge,
<span;>I pressed the button for reset and held it for 10sec, but again only the humming sound/vibrating, no display of the smily face. I retried, waited 15 min and tried it again. No change. There is no syncing or charging either.
<span;>Please advise..
01-25-2022 04:16
01-25-2022 04:16
I have exactly the same problem, and spent a lot of Saturday and Sunday with Fitbit Support trying to resolve without success. When I restart (reset) I get the vibrating and smiley face, but nothing thereafter. I am also unable to sync with my smartphone app. Very frustrating as I depend on my Charge 4 for my workouts. Now FitBit tells me that they cannot help as my unit is 24 days out of warranty. I have asked them to reconsider and waiting to hear. Good luck, Fitinsing, on your issue. Please let me know what develops.
01-25-2022 20:22
01-25-2022 20:22
Will let you know, but how did you get Fitbit response to your problem?
Best Answer01-25-2022 21:34
01-25-2022 21:34
01-26-2022 00:17
01-26-2022 00:17
<span;>Just to give you an update.
<span;>It seems, it fixed itself.
<span;>Overnight the battery drained to 0%. I decided to give it another try this morning.I connected my charger4 to the battery charger and now it is charging and syncing to my phone.
<span;>Everything works perfectly.
<span;>I will keep the Twitter account in mind, when I am confronted with some problems again.
<span;>Thanks
Best Answer01-26-2022 01:28
01-26-2022 01:28
