No display on fit bit 2
Fit bit working but not showing any display on wrist band trying everything but very concerned that I need a replacement I will not spend if there is no support!
4 REPLIES 4
Warranty is here
Contact Support
Community Council Member
Wendy | CA | Moto G6 Android
Try a Restart and do it several times if necessary.
Fitbit have been awesome and replaced under warranty thanks for your help
You are not alone, thousands of people are frustrated with the latest update. No heartrate, blank screen, charging problems and only basic sleep cycles
