05-25-2019
11:10
11:01
05-25-2019
11:10
11:01
Good evening
My fitbit has a blank screen and there is no green light. I tried the suggestions of restarting but nothing happens. The smiley face appears and then goes . I cannot change the clock face because it is not syncing.
Can anybody help?
05-26-2019 00:09
05-26-2019 00:09
My HR Inspire is doing exactly the same, it just went yesterday. I have only had it 2 months. Permanent Blank face, I get the occasional smiley face when trying to restart and it Won’t sync to try clock face change. I have also tried the restarts suggested but had no luck.
By what I have read yesterday it’s a common problem and Fitbit are aware of it and the update was to help fix it, but I can’t sync my Fitbit to download the update.
Unfortunately i think you will will need to call the Fitbit helpline to get a replacement, it’s what I am going to do today. Let me know how you got on.
Best Answer05-26-2019 00:11
05-26-2019 00:11
Forgot to mention that I have no green lights either.
Best Answer05-26-2019 00:15
05-26-2019 00:15
Best Answer05-26-2019 01:40
05-26-2019 01:40
Unfortunately the Fitbit helpline was not able to fix my issue and a replacement tracker is being sent out today.
They did say that the new update fixes the issue so I would download it ASAP if you haven’t yet.
Glad you managed to fix yours 😊
Best Answer05-26-2019 08:04
05-26-2019 08:04
Best Answer04-16-2020 21:41
04-16-2020 21:41
How do they suggest we download the update if the inspire HR won't connect to the phone?
