06-15-2017
08:01
09:49
06-15-2017
08:01
09:49
I'm not connecting to get notifications
11-28-2018 03:08
11-28-2018 03:08
Thank you , that has done the trick!!!!! I have an iPhone 5s and that has just worked. Was thinking of ditching Fitbit fot an Apple Watch. I love my text alerts. 👍🏼😀
Best Answer12-26-2018 13:42
12-26-2018 13:42
Thank you Danae..just spent the better half of the morning trying to google and figure it out. Nothing worked till I saw your post!!! Thank you again!!!
Best Answer01-10-2019 17:09
01-10-2019 17:09
Not working on my iPhone 7 ? Don’t have the show in history option in notification ?
Best Answer05-23-2019 13:05
05-23-2019 13:05
The above worked for me on iPhone 7
Best Answer06-06-2019 17:29
06-06-2019 17:29
I have the iPhone XS and all I was receiving on my new Alta HR was call notifications and calendar notifications. I searched for the past 4 months, tried every single suggestion and just gave up. NOTHING worked! Today I gave it one more try so I did this.....
Settings ---- Notifications ---- Picked my "messages" app ---- Allow Notifications ---- Under Alerts I made sure Notification Center was selected.......suddenly my Alta HR vibrated ---- I got someone to text me and VOILA!!!! Now I get texts!!!!!
10-09-2019 19:26
10-09-2019 19:26
I have an iPhone 7 and don’t see the show in history in messages. Any advice ?
10-16-2019 14:40
10-16-2019 14:40
On iPhone 7, go to settings, notifications, messages, and if your show messages is set to never, change it to when unlocked or always. Fixes the problem right up. Let me know if it works for you.
Best Answer10-16-2019 14:42
10-16-2019 14:42
Just posted what worked for me, give it a try.
01-17-2020 14:44
01-17-2020 14:44
None of the suggestions work to restore text messages to my versa
Best Answer01-17-2020 14:46
01-17-2020 14:46
Same here. I've literally been driving myself insane trying to fix this. I get EVERY SINGLE OTHER notification except my texts. Soooooo beyond frustrating.
Best Answer01-17-2020 14:47
01-17-2020 14:47
Same here. I am so upset by this.
Best Answer01-17-2020 14:54
01-17-2020 14:54
Same problem here. I have galaxy s10. Nothing works and fitbit offers NO HELP.
Best Answer02-01-2020 07:49 - edited 02-01-2020 07:55
Thank You so very much for sharing Danae! After over a year and a half of no longer getting text messages you have solved my problem. Many Thanks! MR
02-07-2020 00:40
02-07-2020 00:40
Hi, You are welcome, I spent ages trying to work out what was wrong with my Fitbit and I found it very frustrating, so when I found a solution I thought by posting it here it may help others, glad it worked for you 👍🏻😃
06-26-2020 20:23
06-26-2020 20:23
I have tried to fix my text message notifications on my Fitbit for days and this was the only fix! Thank you so much!
Best Answer06-28-2020 04:55
06-28-2020 04:55
