09-20-2016
00:35
10:26
09-20-2016
00:35
10:26
03-27-2017 15:02
03-27-2017 15:02
@krq316 wrote:https://help.fitbit.com/articles/en_US/Help_article/1610
Tips
- If your mobile device has a text conversation open, you won't receive notifications from that conversation.
- If you miss notifications occasionally, it may be because your tracker was syncing at the same time the notification arrived.
- If you're receiving notifications but they seem delayed, the Bluetooth connection between your tracker and your mobile device may be unstable. If Bluetooth regularly fails you should notify your device manufacturer.
- If you have another Bluetooth device connected to your mobile device, it may cause interference that prevents notifications from appearing on your tracker. For more information, see The Fitbit app for iOS is interfering with my other Bluetooth devices.
- Make sure the Do Not Disturb setting on your mobile device is turned off because it prevents the device from sending notifications to your tracker.
- If you have Fitbit Blaze, Fitbit Charge 2, or Fitbit Surge, make sure your Notifications are turned on:
- For Blaze, hold the top right button for a couple seconds to make sure Notifications is set to On.
- For Charge 2, from the clock screen, press and hold the button to make sure Notifications is set to On. Keep in mind notifications must be turned on to receive reminders to move throughout the day.
- For Surge, swipe to Settings and make sure Notifications is set to On.
- If you turned on notifications from third-party apps for Blaze, keep in mind only apps that send notifications to your mobile device can send notifications to your tracker. If you’ve received a notification on your mobile device from an app such as Facebook, but you don’t see Facebook as an option under App Notifications, complete these steps in the Fitbit app:
Yes my fitbit wasnt shwoing the notifications anymore- so I went through the app and made it display again and your right the notifications said off- thanks sooo much I was worried my fitbit wasnt working anymore! thanks so much
Best Answer08-01-2017 16:42
08-01-2017 16:42
My Fitbit worked well for about 1 month getting the vibrations of phone calls, texts, 10,000 steps etc. but now nothing. Any suggestion?
Best Answer08-01-2017 19:52
09-12-2017 02:09
09-12-2017 02:09
Follow these steps:
Under Fitbit menu click 'Menu Items'
Check 'Notifications'
Make sure your Fitbit syncs
Now using your Fitbit side button, push until you reach the 'Notification' screen. It probably says 'OFF'
Push and hold the side button to enable notifications.
Mine worked when I first bought it and then all notifications stopped. So I did this and now it's all back on. 😁 Hope this helps you guys!
09-21-2017 12:55
09-21-2017 12:55
Press and hold the button on the left of your charge until it says notifications on (or off).
Best Answer11-13-2017 17:43
11-13-2017 17:43
I had the same problem I deleted it from Bluetooth on my phone and removed it from the app then I added a new device and set everything up again it works great now!
Best Answer10-17-2018 19:24
10-17-2018 19:24
THANK YOU!! I read *every single message* and tried every single thing people were advising to do, and yours was the only one that helped. Not sure how the “Notifications” under “Menu Items” got switched off (I certainly did not go in there and do it!), but it somehow did! Thanks to your advice, I switched it back on, and am now getting text and phone alerts - yay!! Tomorrow will be the ultimate test, though, to see if I get my reminder to move alerts. I am assuming they will work, but thanks anyway in advance! It has been a week and a half of no alerts - very sad - but ecstatic now!
Best Answer10-17-2018 19:33
10-17-2018 19:33
Best Answer01-10-2019 11:49
01-10-2019 11:49
if you buy your Fitbit at costco they would just replace it. just fyi
