Not possible to change training days in weekly goals
It’s not possible anymore to increase Or decrease the days from 3 to another number in the app. If you click another number and you go back because there is no “ok” or “finish” button it turns on 3 days back
already reinstalled the app
1 REPLY 1
@SunsetRunner Thanks for joining us!
Let me help you changing the amount of days to exercise on your Fitbit app. This is odd. Could you share a screenshot of what you are seeing on your app? Which phone and which OS version is it running? Using Android I just go to exercise goal then tap the gear icon finally tap the Weekly Exercise Goals, select the option you want and tap save at the Top right corner.
I look forward to your reply.
Alvaro | Community Moderator
