12-29-2016
17:18
10:13
12-29-2016
17:18
10:13
Hi there! I received my fit bit as a gift on Christmas. I set it up that day and it was working perfectly. I charged it and now I am not receiving any text messages or calls on my Fitbit. I checked the Bluetooth connection and my app for notifications and they're all on.
12-30-2016 03:25
12-30-2016 03:25
Make sure your Charge 2 shows that "notifications" are on. I have accidentally turned it to "OFF" when placing in charger to charge. (Press and hold side button)
As for iPhone users - make sure on the iPhone's settings you have "Allow in Notification Center" "Show in Notification Center", and "Show on lock screen" all enabled.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
12-29-2016 17:45
12-29-2016 17:45
@SunsetRunner What phone are you using? Let us know, and perhaps we can offer some suggestions to help.
Kelly | Oklahoma
12-29-2016 18:43
12-29-2016 18:43
I'm having the same problem - it was working great until I charged it last night.
I have an Iphone 6S
12-29-2016 18:45
12-29-2016 18:45
Same p
Same Problem. Worked on Xmas - charged it last night - now it works fine - but no text or call notifications.. I have iPhone 6s
12-29-2016 18:47
12-29-2016 18:47
I have iPhone 7 plus I can't get text messages on my phone either. All notifications are on can't figure it out
12-29-2016 18:48
12-29-2016 18:48
I have iPhone 7 plus I can't get text messages on my Fitbit charge 2 either. All notifications are on can't figure it out
12-30-2016 03:25
12-30-2016 03:25
Kelly | Oklahoma
12-30-2016 09:08
12-30-2016 09:08
iPhone 6s
12-30-2016 09:08
12-30-2016 09:08
12-30-2016 09:10
12-30-2016 09:10
Thank you! Holding the side button worked!
12-30-2016 20:58
12-30-2016 20:58
I have the iPhone 7 plus. Thanks for the offer to help.
01-09-2017 11:59
01-09-2017 11:59
I checked all notifications and they are on. How do I get it to work?
01-09-2017 12:02
01-09-2017 12:02
01-09-2017 12:04
01-09-2017 12:04
@Chasegirl3 @narbrewer I'd first recommend that you make sure that you are using the latest version of the Fitbit iOS App that was released this morning, version 2.31. Click here to be redirected to the iOS App store if you haven't already updated.
Please keep in mind that you won't receive a notification on your Charge 2 if you have the Messages app open on your iOS device. This could be a potential cause to why you didn't receive a notifications.
Next, I would recommend that you have notifications enabled in your iOS settings. You can verify this by: opening your iOS settings > tap "Notifications" > scroll down and open Phone, Messages, and/or Calendar > make sure that you've toggled "Allow Notifications".
If the problem persists, I'd then recommend the troubleshooting steps mentioned here.
01-11-2017 16:33
01-11-2017 16:33
Thanks!! I had a sneaky suspicion user error was involved.
01-11-2017
16:40
13:11
DerrickS
01-11-2017
16:40
13:11
DerrickS
I'm using HTC ONE A9. pls help what settings I need to do to receive call/text notifications.
Moderator Edit: Edited font style.
02-03-2017 05:56
02-03-2017 05:56
Thank you. Yes, I remember seeing this button show up and I didn't know what it meant. I am back to receiving my notifications again. Thanks. 🙂
02-10-2017 13:02
02-10-2017 13:02
Hi - my notifications are on (Fitbit charge 2) but I'm not receiving them. Thanks for the help
02-10-2017 13:17
02-10-2017 13:17
@TNH First make sure that you have notifications turned on on-device for Charge 2. You can toggle this on/off by holding the button for 3 seconds when its displaying the clock.
I'd also recommend verifying that you have "Enable Notification Widget" and "Always Connected" turned on in the Fitbit Android App.
Hope this helps!
02-11-2017 04:47
02-11-2017 04:47
