09-12-2017
05:14
09:26
09-12-2017
05:14
09:26
Hi all my fitbit charge 2 has not been tracking my active minutes for the past 3 days and kind of p#$ing me off ive reset it ive charged it ive sync it nothing seems to work i do 60 to 120 min walks and i look at my active minutes and guess what it says 0... i dont expect to pay the sort of money for the thing not to work correctly any help would be awesome
12-30-2019 04:07
12-30-2019 04:07
12-30-2019 13:05
12-30-2019 13:05
Patience system corrected itself
12-30-2019 15:03
12-30-2019 15:03
Mine would no longer show active minutes when I was on the treadmill. If I walked outside, it worked. The only way it will detect my activity on the treadmill is if I move my arms like I would on an elliptical.
12-30-2019 15:11
12-30-2019 15:11
12-30-2019 15:58
12-30-2019 15:58
Yes @ingoingknave49 your tracker is mounted on the wrist. And looks at wrist movements to try and figure out what the legs are doing.
If your arms are not moving in a way that says your legs should be moving. Will Fitbit be able to count leg movements.
@DRoque in the same way, holding on to the cart may not allow steps to be counted. Fitbit has been able to fine tune to catch steps while pushing a baby carriage but they are a lot lighter then a shopping cart.
As for holding on while using a treadmill this habit will considerably reduce caloric burn. Also can cause repetitive leg injury and cause the person to unlearn the art of balancing while out on a free run. I'll let you search out the other 8 problems with holding on.
01-29-2020 14:12
01-29-2020 14:12
I would like to know why when I grocery shop my Inspire HR doesn't track my steps.
01-30-2020 01:28
01-30-2020 01:28
Is your Fitbit arm holding the carriage, or shopping cart? Try holding the handle loser so the wrist bounces with each step. If the arm is gliding across the floor with the carriage, no steps will be counted.
01-30-2020 13:36
01-30-2020 13:36
