12-17-2018
11:59
14:31
12-17-2018
11:59
14:31
Hello,
Edit: I posted this before I updated to the new version of the app (Android) that was released on the same day. Last night, I got a nice sleeping stages view and following with an automatic separation of the 'Nap time' with patterns that happened right after...
I'm hoping this will be delivered to the Fitbit tech team, as I'm (and many other) experiencing issues of sleep tracking does not show the sleep stages only the pattern. Usually, it works fine for a bit, and than suddenly, no more sleep states.
if you search about this issue, you will find a lot of suggestions to fix this problem from reset your device, the location of the Fitbit on the wrist (constant heart rate) to remove the sleep data and add it again. None of them are the cause of the issue, as for most of us, it worked perfectly until it didn't.
I think that I found a hint for that the issue might be, and hoping that the Fitbit team will get it and will investigate further. I think the issue is with the backend when processing the data, and I have a proof for it!
In the past two months of owning the Charge 3, after i suddenly stop seeing the sleep stages, I have noticed that at times when I awake in the middle of the night, I see the stages, and in the morning, they are gone, converted to patterns. I had two theories: 1. Is that as soon as the device sense a nap that follows the night time sleep, it flag the entire sleep duration as a nap and therefore, does not shows the sleep stages, and, 2. I have notices that the heart rate actually sync few min AFTER the sleep is, which, if following the rules, sleep stages needs heart rate measurement, and if the app does not get it, it will not show the stages.
However, today, I had the perfect opportunity to proof that something is wrong with the backend process, and I would like to share my finding with you all.
Please see the attach screen shot below and note the time stamp:
at 7:12am I got a nice sleep stages view (left), and at 9:02 it changed to sleep patterns (right).
immediately, I have noticed something else - the sleep tracking indicates that I was a sleep until 8:11am, while in reality, I was already 11 minutes in my first work meeting of the day.
now, things are getting interesting... I was thinking: what if I'll delete the data and add it again only until 6:49am, Do I get back the sleep stages?... and I did! , from there, I wanted to find the exact point where the sleep states transformed into sleep patterns, and I found the exact moment: 7:01am to 7:02am.
See the screenshots below.
Here, at 7:02am (left), it shows the sleep patterns, and indicates that I slept for 7 hours and 37 min, now, I have deleted the data and added it again, this time ONE MINUTE less, to 7:01am (right), and behold! I have the sleep stages again! and weirdly enough, my sleep duration has changed to 7 hours and 2 min. There is a 35 min difference in the sleep duration between one minute of sleep data (which may be because with the sleep stages I'm getting more accurate count of minutes being awake, and I'm too lazy to actually do the calculation, so, please excuse me for not going all that scientific 🙂 )
I'm sure the Fitbit QA team will find this interesting and will proof that something in the back end calculation is wrong... and just to point out: this is not a odd one. I have managed to repeat this in other past occasions.
Hoping this would help to solve the issue.
12-19-2018
03:17
04:34
12-19-2018
03:17
04:34
Hey @G45, it's great to see you around.
I appreciate all the information and attachments provided. It's great to know that you found a solution for this issue and that your sleep information is now fine. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up! ![]()
Best Answer12-19-2018 09:49
12-19-2018 09:49
Unfortunately, I celebrated too soon...
yes, I do have the newest Android update. Yes, it did worked for one night (as my edited note said). But, it again, for last night report, its showing the sleep patterns instead of stages.
I did tried to do the thing I described on my initial post, but, no luck. I did noticed that the heart rate data syncs minutes after the sleep data did, which might be the reason...
Tonight, I will try to reset the device and see what the morning will bring.
12-23-2018 00:27 - edited 12-23-2018 00:29
I'm also having an issue with my Charge 3 having stopped recording my sleep stages.
I have restarted the band, checked how I am wearing it. I haven't been as organised as you G45 🙂
I do find it odd that it appears a few of us are having issues with it recording sleep stages around the same time as both each other and a firmware update.
My Charge 3 records my Heart rate just fine during the day and was recording my sleep stages up until 3 nights ago......
Does anyone have an ideas that aren't, restarting the band or checking the bands position for those of us who have already done that?
Thank you in advance!
12-24-2018
04:02
08:26
12-24-2018
04:02
08:26
Thanks for the update @G45 and @JennyPass it's great to see you here.
There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
Let me know how it goes. ![]()
Best Answer03-19-2019 18:08
03-19-2019 18:08
i always use the Begin Sleep now, but get the straight bars, and no real reference to time intervals. in December 2018 i got the wavy lines, apparently the new Version only shows straight vertical lines. i agree IT needs to fix. (user should NoT have to edit data) otherwise why buy a product that does live up to what was expected
07-25-2019 04:50
07-25-2019 04:50
I have a Fitbit inspire for 4 days. Two nights it showed sleep stages, two it didn’t. It’s pretty frustratinh.
08-16-2019 02:31
08-16-2019 02:31
I’m having a sleep stage issue too. It worked for several months and suddenly stopped recording sleep stages. I tried recommended fixes..making sure band was properly positioned etc. not using begin sleep now feature. What else can I do? So disappointed this isn’t working.
i also cannot change the time on the watch to ET. I change it in settings but the watch doesn’t change... it shows Los Angeles but should be NY. Again..so disappointed. Fitbit is not a device I would recommend. It is seriously flawed
09-27-2019 22:47
09-27-2019 22:47
I am tired of reading these same old suggestions. I've tried everything suggested (i.e. repositioning the device on away from my wrist, making sure that it is tight but not too tight, seeing that my battery is well-charged, etc.), but none of these steps appear to have any reliable effect. My Fitbit shows sleep stages for a couple of months, then stops. Maybe now and then it will work for a day, the then not thereafter. Then all of a sudden it resume working and function fine constantly for a few months. In short, it is completely unpredictable and completely frustrating. A major reason I purchased my Fitbit was because of the sleep tracking. Now it is again in a non-functioning sleep stage tracking phase. I was about to purchase a premium membership last week, but then right when I was ready to do so, that is when my sleep stages stopped working. No way would I buy an upgraded membership now that the device again stopped recording sleep data properly.
10-07-2019 09:54
10-07-2019 09:54
I seem to be having the same problem with sleep data too, a bit disappointing as the only reason I got this device to track sleep data. This is my 3rd night of using fitbit, 1st night worked fine the other two did not. After reading other posts I am considering returning the device. I gonna try to reset the device this evening but it is about ridiculous that bran new device works only 1 out of 3 nights...
10-10-2019 07:04
10-10-2019 07:04
Best Answer10-10-2019 07:35
10-10-2019 07:35
10-10-2019
09:03
06:11
JuanJoFitbit
10-10-2019
09:03
06:11
JuanJoFitbit
Why assist? You clearly stated you we tired of the same old information.
Attack? You attacted those who tried to assist. I gave you information
regarding a course of action, since this forum did not seem to meet your
desired outcome.
A softer approach would be far more effective.
Please reread both posts. I'm sorry you took it personally. Again, I wish
you well in your search. I sincerely encouraged you to share information,
if it can be found.
Thank you for your response.
Unfortunately, I don't read minds. Having no idea "who else makes use of that tactic." Please, please oblige me!
My only guess would be the same person who hides behind their own words.
Moderator edit: merged reply
Best Answer10-19-2019 05:53
10-19-2019 05:53
I have had the same issues with my Android. Sleep stages worked fine until 45 days ago.
11-04-2019 18:06
11-04-2019 18:06
I also have the same problem and I've tried all the suggestion which haven't worked for me.
11-04-2019 22:32
11-04-2019 22:32
Hi Lorrie, I think I have found the trick to get this working. Try to strap the watch loosely so you can move it over your wrist bone. Since I have done that I get the reading every night.Give it a go it might work for you too.
Best Answer11-05-2019 18:35
11-05-2019 18:35
Thank you Chris. Are you saying to put it on the wrist bone? Or in front or back of the wrist bone? I’m willing to try anything in hopes of getting results.
Best Answer11-06-2019 00:58
11-06-2019 00:58
Hi Lorrie15,
I think what they advise is the watch to be two fingers away from wrist bone. What it makes work for me was strapping it loosely, so you can almost move it over wrist bone ( i have a skinny hands 🙂 ). I needed to play with how loose it needs to be to do reading and find a sweet spot. I suggest to try it out with different holes on the strap to see if that works for you. I will try to post few pics in next few days, if possible to show you how I have got it working. Let me know if that has worked for you.
Best Answer11-11-2019 13:54
11-11-2019 13:54
Thank you Chris. I tried your idea and still didn’t work. I’ve tried wearing it on the inside of my wrist which didn’t work either.
Best Answer11-18-2019 04:33
11-18-2019 04:33
Hi! My Husband bought be a charge 3 for my birthday this month ..... solely for the sleep tracking. I have had issues from day one with receiving sleep stages/pattern information. I spent a week on the phone with fitbit for the conclusion being that I had a bad device. They sent me a new one. *Drumroll* ..... I woke up this morning using my new device and no sleep stages appeared along with some data missing regarding my night of sleep. I give up. This device will be returned if I can’t get the sleep stages AND patterns to appear as it should.
