06-04-2019
18:07
15:47
06-04-2019
18:07
15:47
My Fitbit is not syncing to weight watchers app. It was fine yesterday’s. I have logged out of both apps and tried disconnect and reconnect
06-05-2019 19:14
06-05-2019 19:14
It only temporarily fixes it. I have been disconnecting and reconnecting for two days now.
06-06-2019 04:31
06-06-2019 04:31
I’m happy to report that I had to reconnect my Fitbit device in the WW app last night, but then it synced, capturing all my previously lost activity. WW has resolved the issue.
06-06-2019 06:48
06-06-2019 06:48
06-06-2019 07:03
06-06-2019 07:03
06-12-2019 12:25
06-12-2019 12:25
Hello everyone.
Let me help you with your Weight Watchers link with your Fitbit account. If you are having issues please revoke access to the app by going to the Fitbit website. Do the same from the WW side and then relink them as you initially did. If the issue persist you can ask WW if they have any suggestion from their side.
Also check @CindaRella suggestion.
Let me know how it goes.
07-08-2019 17:30
07-08-2019 17:30
Mine either, I have tried everything suggested and it still wont sync
07-08-2019 18:51
07-08-2019 18:51
Go to WW app reconnect your Fitbit then try to sync. Go to Fitbit then manage data then revoke applications and WW should show up
07-09-2019 18:05
07-09-2019 18:05
I've done that at least 50-60 times. It is driving me crazy
07-09-2019 19:37
07-09-2019 19:37
