07-16-2017
04:03
20:15
07-16-2017
04:03
20:15
Charger hr not showing sleep pattern or monitoring heart rate. Anyone else having this problem?
07-17-2017 08:42
07-17-2017 08:42
Hello @Brooklyn3190, I'm excited to welcome you to the Community forums.
It's really odd that your Charge HR is not tracking properly your heart rate and the sleep, I recommend following these instructions so you can fix both inconveniences in a row:
I also suggest trying the tips my friend @FerdinandFitbit posted to improve the accuracy of the heart rate readings.
Hope this helps and let me know if you have questions.
What's for breakfast?Check others recipes and share yours!
07-17-2017
13:33
07:52
MarlenS
07-17-2017
13:33
07:52
MarlenS
Got it to work thank you 🙂
Restarted tracker heart monitor is working again thanks
Moderator edit: content.
07-19-2017 08:03
07-19-2017 08:03
Hey @Brooklyn3190, it's nice to see you again. I'm glad to know that the steps I posted above helped you to fix this issue. Now that you're back on track I invite you to continue digging in our Community, you can find here the option to suggest your ideas to change and improve our products and services, you can also find awesome discussions where you can make new friends, find other Fitbitters sharing their experiences and motivation and much more.
Hope to see you around the forums!
06-29-2019 05:47
06-29-2019 05:47
My inspire HR is doing the same thing. No heart rate and no sleep tracking. Has trouble syncing half the time and it is an IPhone XS so it should work
