04-05-2016
23:46
20:15
04-05-2016
23:46
20:15
The Dashboard used to work now nothing. Nothing on both my computer or ipad. Should I take this back?
04-06-2016 07:01
04-06-2016 07:01
Welcome to the Forums @chezem. First, please verify that your tracker is paired, if it not paired follow the Setup Instructions from your iOS Fitbit app. You can also, do the following:
1. Open the Fitbit app.
2. Tap Edit in the top-left corner.
3. Scroll to the bottom of the page.
4. Check the circle next to the tile you would like to show.
5. Tap Done when finished.
I hope this helps, let me know the outcome! ![]()
Best Answer02-06-2019 15:16
02-06-2019 15:16
I have Charge 2. On my dashboard, suddenly disappeared everything except calories
