10-15-2018
03:18
15:06
10-15-2018
03:18
15:06
Today I got a few WhatsApp notifications. Normally no problem, but right now the "clear" button does absolutely nothing. I've tried swiping the message every which way to no avail. It simply won't return to the clock face no matter what I do. Holding the button brings me to the settings menu, but even playing around with those does nothing.
I'm away all day with no option to grab the charging cradle and reset the device!! In the meantime the divice is absolutely useless to me. Extremely frustrating that there's no way to reset the device in the go, this is some seriously crappy anticipation in the design for a device which only needs to be charged every few days.
02-14-2019 15:24
02-14-2019 15:24
You saved my sanity! The 3 button trick worked. My Fitbit was showing me old notifications from multiple sources over 3 or 4 days old and voila! Good to go! Thank you!
Best Answer02-17-2019 08:24
02-17-2019 08:24
Changing the clock face worked, thank you!!!
Best Answer02-22-2019 02:58
02-22-2019 02:58
Great it works pressing the 3 button s thank you
Best Answer03-02-2019 10:50
03-02-2019 10:50
This worked for me too. Thank you
Best Answer03-07-2019 06:44
03-07-2019 06:44
Oh thank you! It is so annoying when it gets stucked!
Best Answer03-08-2019 18:11
03-08-2019 18:11
Thanks Sarah, worked perfectly for my Iconic. Cheers.
Best Answer03-21-2019 03:57
03-21-2019 03:57
Same. Regular text notification stuck. Changed the clock face as suggested, and it cleared. Thanks!!!
Best Answer05-21-2019 19:44
05-21-2019 19:44
Thank you so much for this tip! Holding the three buttons until I saw the Fitbit sign worked to clear my calendar notification! It was driving me crazy!
Best Answer06-27-2019 20:59
06-27-2019 20:59
Thank you for this post it also worked for me
Best Answer07-12-2019 07:56
07-12-2019 07:56
This worked for me! I think the main problem was the clock face and the notifications. I was ready to take my Fitbit Charge 3 back to the store.
Best Answer03-16-2020 10:40
03-16-2020 10:40
Sarah!! you are an angel, I've been dealing with this problem one month ago! thanks for the tip!
Best Answer06-10-2021 03:23
06-10-2021 03:23
i have a fitbit versa 2 and it only has the one button. what should i do?
i
Best Answer08-02-2021 23:38
08-02-2021 23:38
I've had the same problem for weeks. For me changing clock faces didn't work. The notification was still there and clearing it still didn't work. So I went into settings on my watch and pressed shutdown. When I turned my watch back on it had magically disappeared!
