01-13-2017
06:17
10:13
01-13-2017
06:17
10:13
I see that many people are having the same type of issue in one way or another. I see one has been marked resolved however, a firm direction on how to correct things was not given.
I have done a couple of FitBit Charge 2 "restarts" and that didn't correct my issues. I gathered that another solution might be to "unpair" my FitBit Charge 2 from all devices and then pair them again. I will try that.
My issues are:
And yes, my notifications are all set to "on", on my FitBit Charge 2 as well as the aps (iPhone & computer).
Any suggestions would be greatly appreciated!
Happy Friday!
01-13-2017 06:49
01-13-2017 06:49
I have also tried the restart and the unpair but am not able to receive text messages. My other messages seem to still work fine. I will follow this thread in the hopes of an answer too.
Thanks for posting your question as it will, I'm sure, help others as well.
01-13-2017 06:57
01-13-2017 06:57
going to follow because I have the same issues. they say they opened a CASE for me....
01-13-2017 06:58 - edited 01-13-2017 06:59
Hello guys @GrandmaKay @DawnXXOO @judyelaine, hope you're doing great! Hmmm... very strange.
Before moving on some troubleshooting steps, please make sure about the following requirements:
If you have checked and still not working, follow these troubleshooting steps:
Keep me posted!
01-13-2017 07:11
01-13-2017 07:11
01-13-2017 07:17
01-13-2017 07:17
Yeah it's.. please get in touch with our support team directly so they can do a deeper investigation and see where the issue is coming from.
Don't forget to mention the steps you've done so far to avoid getting the same ones and share here with us the outcome!
02-27-2017 15:03 - edited 02-27-2017 15:05
it took forever to get mine resolved (and not entirely to my satisfaction)and talking to several "teams" because you get a different one everytime you respond and they don't read what the last team wrote. they keep telling you to do the same thing. They finally admitted there was something wrong with the Charge2 and sent me a new one that works fine other than it will not sync with my windows 10 computer but it will sync with my phone consistently(which was also a problem before and I could never get the information to update anywhere). I'm not about to complain because I can't go through what I went through with them before. the moderator here was more helpful. I ended up having to get really angry to get anywhere with them. they also made me a goofy offer of 30 % off of an upgrade without subtracting the cost of the worthless Charge 2 I already earned, so I would have been stuck with the cost of a worthless Charge 2 and 30% off of a new upgrade like a surge, making the cost of an upgrade more expensive (...over 320.00 on a $249,00 Surge)and they didn't understand my anger. good luck.
02-28-2017 05:41
02-28-2017 05:41
Thanks for the help and I have done all that, but my issue is that I don't get the reminders to move.
I have set and reset them and gone trhough all the steps for restarting, unpairing from my iphone, etc. I have not other blue tooth devices connected.
I get the text and phone alerts, no issue there.
Any further assistance would be appreciated!
02-28-2017 06:20
02-28-2017 06:20
Just had a thought....if you already have your 250 steps in for the next hour, you will not get a reminder to move. I only get mine on Sundays when I'm sitting it church or am traveling... so if your already conscientious about moving, that could be your issue. They ususally come about 10 minutes to the hour.
02-28-2017 11:40
02-28-2017 11:40
03-08-2017 13:31
03-08-2017 13:31
Both my husband & I have the same problem with Charge 2 & lack of notifications & texts. Well try some of the solutions.
03-17-2017 17:55
03-17-2017 17:55
I had turned off to 'show in notification center" in the notifications on my iPhone under the Fitbit tab once I changed that, it worked like a charm.
06-23-2017 16:00
06-23-2017 16:00
Thanks for the information on getting notifications to work again, It is on now and I don't know how it was turned off in the first place. thanks again Marre
07-02-2017 16:55
07-02-2017 16:55
Hi all, just got my Charge 2 yesterday. Is it normal that the tracker vibrates upon receiving phone calls and messages but does not display? Only shows the ID and messages once I turn on the display (by pressing button or tapping). Used to have a Charge HR and it always showed ID so not sure if Charge 2 works differently. Cheers.
07-03-2017 05:46
07-03-2017 05:46
10-20-2017 08:32
10-20-2017 08:32
I'm having the same problem, but with Android.
10-20-2017 11:38
10-20-2017 11:38
Have you read @MarreFitbit's post above. Especially the point about checking the notification status on the tracker?
10-24-2017 01:06
10-24-2017 01:06
Hi!
just got a flex 2 and it will not respond to my text or call notifications, still awaiting the keep moving and other notifications. I have tried all the steps, help!?? Thanks!
03-27-2020 09:57
03-27-2020 09:57
I’m having an issue with not receiving text notifications only. It vibrates and shows me who’s calling, and vibrates to remind me to get my steps for the hour. But texts haven’t come through in months. I have the iconic. It stopped sometime after and apple update. Fitbit’s app said it was going to have to update so I just kept waiting but nothing. Suggestions?
03-28-2020 08:56
03-28-2020 08:56
@Tonythetiger014 DIY you by any chance have an iOS device with version 10, it sounds like you haven't made the changes needed to your phone.
