03-09-2017
13:36
09:49
03-09-2017
13:36
09:49
I loved how on my original Charge HR it would vibrate when I hit my goals or if I received a text or phone call. My new Charge 2 does not do that. Is there a setting that I just don't have set right perhaps? Help!!
03-09-2017 14:07
03-09-2017 14:07
Hi @MichelleJDean. If you go into the settings in the app, under menu items, make sure Notifications is checked and Reminder to Move is turned on, and perform a sync. Then on the tracker, page through until you get to Notifications, and make sure it's turned on. That should get you going.
03-09-2017 14:27
03-09-2017 14:27
Hi and Thank you! I am trying to find the settings in my app to follow what you replied. Wish me luck - i'm not very good at this!
03-09-2017 14:28
03-09-2017 14:28
Found it Dave! Thank you so much! Will give it a try!
03-09-2017 14:37
03-09-2017 14:37
well notifications are on ... in both my iPhone app the fitbit app and on the fitbit it self but it still won't vibrate 😞
Best Answer03-10-2017 07:50
03-10-2017 07:50
Hey @MichelleJDean, it is great to see ya' around and thanks for following the instructions that @WavyDavey posted above to turn ON the notifications on your Charge 2. Since your Fitbit still not vibrating, I suggest restarting your Charge 2 by following the steps on this post.
Let me know if that works!
Best Answer03-10-2017 13:43
03-10-2017 13:43
Thank you for the info but it won't vibrate even after I did the restart ... it doesn't even vibrate after holding 4 seconds and seeing the logo pop up 😞
Best Answer03-13-2017 08:35
03-13-2017 08:35
Hi @MichelleJDean, thanks for your reply and the time you have taken to restart your Charge 2. Let me suggest you to try one more thing. Please try to set up your Fitbit as a new device by following the instructions for iOS devices on this post.
Best Answer03-13-2017 08:44
03-13-2017 08:44
I did all of the recommendations and my notifications for text/calls is still not working
Best Answer03-13-2017 09:19
03-13-2017 09:19
My notifications are on on the app on my phone and comupter, I shut off and synced and steps have not changes from yesterday and notifications are still not appearing or vibrating, what should I try next?
Best Answer03-13-2017 09:25
03-13-2017 09:25
My notifications are on on the app on my phone and computer, I shut off and synced and steps have not changed from yesterday and notifications are still not appearing or vibrating, what should I try next?
Best Answer03-13-2017 09:55
03-13-2017 09:55
It didn't work for me either I'm frustrated to say the least 😞
Best Answer12-07-2017 13:08
12-07-2017 13:08
Hi, I just got mine finally! And I have the same problem. I've tried EVERYTHING that I read here... but still does not work. Have you found the result after all??
Best Answer12-07-2017 18:37
12-07-2017 18:37
Best Answer12-07-2017 19:14
12-07-2017 19:14
Best Answer12-25-2017 09:48
12-25-2017 09:48
How do I find the notifications on the tracker. I think I may have accidentally turned off. All other notifications are on, but still not getting notifications on tracker
Best Answer12-26-2017 12:48
12-26-2017 12:48
The easy way @SunsetRunner is to hold in the button while viewing the clock.
Best Answer02-09-2018 15:57
02-09-2018 15:57
Am having the same problem. Phone does not virate with reminders or notifications. Everything is turned on. I do get the notifactions but only if I happened to be looking at my phone. The vibrating part would be helpful. Anyone can help with this?
Best Answer02-09-2018 16:21
02-09-2018 16:21
Mine was totally defected, so I simply returned it and got a new one.
It's perfectly working, I'm so Happy!
You better return it and get a new one, too!
Best Answer02-09-2018 22:15
02-09-2018 22:15
I am having the same issues. I have also tried everything that was suggested and still don’t receive notifications on my fit bit
