09-06-2017
06:25
09:26
09-06-2017
06:25
09:26
I've noticed my sleep and heart rate has not been tracked for 2 days and today I noticed only one green light was flashing.
I have turned sleep off and back to auto
I have connected the fitbit to the charger and held for 10 seconds
I have cleaned it with a wipe
None of the above has worked
Any suggestions????
09-06-2017 06:58
09-06-2017 06:58
@MrsKJ, you need to contact Fitbit Support so that they can help resolve this issue.
Best Answer09-06-2017 07:38 - edited 09-06-2017 07:39
Hey @MrsKJ, it is great to see new faces around! 🙂 Hmmm sounds pretty weird that only one light is flashing on the back of your Charge 2. On the other side, I appreciate that you have taken the time to try to fix this issue. Beside what you already tried, I would like you to try to set up your Fitbit as a new device by following these instructions for iOS devices. If that doesn't work, I'd suggest you something else, could you please the battery of your Charge 2 run out? After that, plug it into the charging cable and perform another restart, then use it for a few days and let me know if it is tracking your sleep and heart rate.
Thanks for your help @USAF-Larry. 😉
I'll be around so keep me posted!
09-06-2017 11:42
09-06-2017 11:42
I contacted the online support services and after more of the same troubleshooting I am now waiting for my replacement Charge 2.
Thank you for your help
09-08-2017 07:09
03-17-2019 01:39
03-17-2019 01:39
I am also experiencing this issue.
03-17-2019 02:34
03-17-2019 02:34
06-20-2020 17:04
06-20-2020 17:04
I am experiencing the same issue. My heart rate is through the roof and my sleep is also not accurate . I have tried resetting and cleaning as well. This is the second time this happened .
06-21-2020 00:29
06-21-2020 00:29
06-21-2020 05:40
06-21-2020 05:40
Best Answer06-21-2020 07:36
06-21-2020 07:36
