01-29-2020
13:29
17:16
01-29-2020
13:29
17:16
Hi Fitbit,
can you please add an option to edit alarms on the Charge 3. I need to get up a different times during the week depending on my schedule and changing alarm times through the app is tedious. Change the alarm, sync fail, alarm gone from the list, restart the app, sync, change alarm, sync,... you get the picture. Something along the lines of settling the countdown timer perhaps?
01-29-2020 14:55
01-29-2020 14:55
Create several alarm times in the app. When you want to set one, you can do it from the Charge 3...just swipe across 2x until the Alarms screen shows, click on Alarms, and all the times you've created will be there, but very dim. Scroll down until you see the time you want to wake up the next morning. When you press it, and it will light up; that's how you know it's set.
I hope this helps!
01-31-2020 16:40
01-31-2020 16:40
Hi there @KevinB123, welcome to the Community Forums. I'm sorry for the late response.
For anything else you would like to see implemented in the future, consider visiting our Feature Suggestions board. This is a space where Community users can post features, ideas, and suggestions that they'd like to see in future Fitbit products, accessories, and software and top-voted suggestions get relayed to our product team for review. You can learn more about how Fitbit decides what suggestions get released in our FAQs.
I'll definitely do what my friend @Godiva14 has suggested. You can set all your alarms in the Fitbit app and manually disable or enable them directly from your Charge 3.
Let us know if you need further assistance.
Best Answer02-02-2020 03:13
02-02-2020 03:13
It's a good suggestion but does not really help here. I need to get up anywhere between 4 to 7am depending on whether I'm traveling that day and if so what time my flight is. Just too many options I'm afraid.
I'll submit Feature Suggestion for this one.
