12-06-2018
15:12
18:22
12-06-2018
15:12
18:22
The charge 2 won't pair with my A8 or Samsung galaxy s8. I followed all the steps and got a code but then the app keeps asking me if I want to install a charge 2. Both telephones should be compatible so that can't be the problem. What do I need to do. I'm getting pretty desperate at this moment.
12-07-2018 08:29
12-07-2018 08:29
Hey @Bregje, let me give you a warm welcome to the Community! Yes, both devices, the Samsung Galaxy A8 and the Samsung Galaxy S8, are compatible with Fitbit devices. So, I'd like you to, first of all, make sure that you have the latest version of the Fitbit app installed on your phones and if so, you can also take a look at the troubleshooting in this help article: Why won't my Fitbit device sync?
Let me know how it goes!
12-07-2018 13:38
12-07-2018 13:38
12-08-2018 09:29
12-08-2018 09:29
Thanks for your reply @Bregje! Is it possible that you can try to set up your Charge 2 by using a computer? If so, please start from scratch. You can take a look at the instructions in this help article: Why can't I set up my Fitbit device for further assistance.
05-03-2019 09:29
05-03-2019 09:29
Hi! my Charge 2 do sync with my Samsung A8 butt will not pair, My phone did an update resently and after that my Fitbit alta and my new charge 2 don´t pair. What can be the problem.
Best Regards
05-03-2019 10:21
05-03-2019 10:21
I have exactly the same issue. The Fitbit and phone are syncing all data but it wont pair to my mobile to receive calls and texts.
Its paired to my tablet ok but that's no good.
I'm so angry I've emailed and been on the phone to customer support but no one can help.
I didn't buy a Fitbit for the steps but purely to have access to calls and texts when I'm at work and cant have a phone on on me. Without this function the whole tracker is useless to me.
07-10-2019 13:17
07-10-2019 13:17
I have the same issue.
Any response from Fitbit?
07-10-2019 13:25
07-10-2019 13:25
07-10-2019 13:39
07-10-2019 13:39
Yes. I first get that it was something wrong with the new Android 9 and fitbit, and that they worked on a solution. And a few weeks ago I received a new email from them. And they suspect there is something wrong with my fitbit, so they should send a new one within the warranty. But I think they are still something wrong between Android 9 and fitbit 🤔
07-10-2019 14:33
07-10-2019 14:33
I got my replacement Fitbit yesterday. Still does not want to pair with the phone. It syncs every now and again, but I keep getting messages saying it is not paired with the Bluetooth. Looking at this post, it seems that it is rather a Samsung issue...
08-04-2019 10:14
08-04-2019 10:14
From what I have understand none of the samsung phones are compatible and that they are trying to get it fix to where they are compatible. I have the same problem.
08-04-2019 22:59
08-04-2019 22:59
Not all Samsung's. Because Samsung galaxy a5 from 2017 still work perfectly with Fitbit. I tested with my child's phone namely. So I know that it works with older model. It's just the new version of the phone that's not work with fitbit. 🙈
08-05-2019 02:39
08-05-2019 02:39
