01-31-2018
11:03
18:54
01-31-2018
11:03
18:54
My fit bit was paired with my phone but now it's not. It's not visible at all.
01-31-2018 14:47
02-06-2018 06:32
02-06-2018 06:32
@Jpointer Welcome to the Fitbit Community! I hope you're doing well! Which phone do you have? Is it compatible to sync? The more information you share the better we will be able to assist you. Like @Rich_Laue said you don't need to see your tracker on your phone's bluetooth settings area since the syncing process is handled by the app itself. Does your tracker shows in the app? This will tell us if the tracker is still paired to your account. When was the last time you synced your tracker (tap the tracker's icon to see this information)? In general a restart of your phone and tracker should help a lot. Restart your Charge 2 by doing the following:
Plug the charging cable to your computer or UL certified wall adapter.
Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Your tracker should start charging.
Press the button for 10 to 12 seconds.
You should see your tracker's firmware version and you can now unplug your tracker.
Let me know how it goes!
Best Answer12-06-2019 08:26
12-06-2019 08:26
Try to plug in then holding for 12 seconds no joy
08:28
06:27
AlvaroFitbit
12-06-2019
08:28
06:27
AlvaroFitbit
Fit bit dead show Ing it went off at 1230 last night
