01-25-2016
18:07
20:15
01-25-2016
18:07
20:15
07-17-2016 22:49
07-17-2016 22:49
Best Answer01-26-2016 00:53
01-26-2016 00:53
It's probably the reason although if a phone is not listed then it only means that it's not guaranteed to work, not that it definitely won't work.
Why not tell us what phone you have. If someone has that phone they may be able to tell you what works for them.
By the way, you say you are having trouble getting the heart rate to sync. Are the other statistics (steps, distance, calories) syncing to your dashboard?
01-26-2016 04:28
01-26-2016 04:28
Its andriod, ZTE Haven. Everything else is syncing fine and I can see the HR on the screen of the tracker but it wont sync into the dashboard
Best Answer01-26-2016 08:44
01-26-2016 08:44
Best Answer07-17-2016 22:49
07-17-2016 22:49
Best Answer07-17-2016 23:56
07-17-2016 23:56
Unfortunately the ZTE Blade isn't on the list of fitbit supported devices at www.fitbit.com/devices
Best Answer07-27-2016 06:22
07-27-2016 06:22
Hi everyone and welcome aboard to our Community @JessMM and @timba. I wonder how it goes with your device @JessMM?.
I'm agree with @SteveH, some devices are not in the list of compatible devices but that does not mean are not compatible. Is just that we cannot guarantee that all the feature will work or it wont present any issue in the future as it has not being fully tested. Nowadays high end devices are built with the same core specification, so is hard to find a device which is not compatible and is rare to find a device which wont be compatible at all.
I have a mobile device that is not in the list of compatible devices, despite all the features works fine, sometimes it syncs my heart rate and other times only shown "--" as @kalimm mentioned before.
If you have further questions, I'll be around.
07-27-2016 06:40
07-27-2016 06:40
@RobertoME thanks for post. one question -- do you know if there are any plans to, instead of the dongle, go away from the dongle and provide syncing capabilities via download (or upload i guess) via the usb connection? I know some other companies do that, and it seems a good fix to some common sync problems.
I sync my Charge HR with my phone, but have another device that isn't compatible with my phone and so I just upload which seems to work fairly well.
Apologies if I strayed off topic a bit, but I think it'd be a great tweak if possible...
Thanks!
02-11-2017 08:15
02-11-2017 08:15
Hi I was wondering if you could help, I have just bought a fitbit charge 2 and bought it cause it would show text/calls however my LG G5 isn't listed and the text/calls don't show up. Is there anything I can do to fix this?
Best Answer02-26-2017 09:13
02-26-2017 09:13
My phone is a straight talk LG Premier LTE LG L62VL
Best Answer02-26-2017 09:16
02-26-2017 09:16
I am having problems syncing it also
Best Answer03-16-2017 08:09
03-16-2017 08:09
Hello @SunsetRunner and @Trafton, let me start by giving you a warm welcome to our Community!
@SunsetRunner The functionality of notifications can be affected by:
Although it wont hurt to try the following steps from this post: My tracker isn't receiving notifications (Android Fitbit app).
In your case @Trafton, the same scenario applies for not compatible devices. However I always like to recommend to give it a try to our troubleshooting steps, so perhaps the following post might be of your help: Having trouble syncing? (here's how to fix this).
See you around and hope this helps.
Best Answer06-02-2017 00:47
06-02-2017 00:47
Hi there
I have a Charge 2 and a Huawei P9 lite and it wont sync as well as I dont recieve text or call notifications and I have enabled it. I am currently syncing it to my mac when I get to work every morning.
Does fitbit update theirs phone compatibility?
Kind regards
Best Answer06-03-2017 08:09
06-03-2017 08:09
Hi there @CJC03, have a warm welcome to the Fitbit Community, it's great to have you on board. ![]()
Even though the Huawei P9 is not yet on the list of compatible devices, if you were able to download and install the app, please try the following in order for your Charge 2 to receive notifications;
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
08-16-2017 01:28
08-16-2017 01:28
I have an Alba phone on Android 5.1 my phone won't connect to my Alta. Tried turning Bluetooth off and on
Best Answer08-16-2017 02:07
08-16-2017 02:07
@TraceyNicholls it looks like you won't be able to use your phone to connect with your fitbit - there are no Alba phones on the list of supported devices at www.fitbit.com/devices
Do you have access to another phone / tablet or could you perhaps make use of a computer to setup and use your fitbit?
Best Answer09-12-2017 16:09
09-12-2017 16:09
My old Alba 5" Smartphone worked fine with Fitbit, although on my new 4" one the app says it can't sync because the phone doesn't have Bluetooth LE (It's supposed to though)
Best Answer09-25-2017 10:13 - edited 09-25-2017 10:14
This is so dumb. I got the first Pebble watch they made, and it was used. It went through two phones before me and two phones while I owned it. I never had a problem with it, till the screen died this year. I bought a Blaze to replace it, and It won't connect with my phone. Fitbit bought Pebble, and I though they were going to bring that quality of product into their brand. I have devices that I didn't spend but 10 bucks on and they work with any phone I through at them. So why can't my $200 watch do the same. Fitbit has learned nothing from Pebble.I am about to give up on the Fitbit brand. It's junk.
Best Answer10-16-2017 09:28
10-16-2017 09:28
I have the Oneplus 5 and I have tried everything and nothing will sync... . Is this going to be a long term thing or should I be looking at another Fitbit.... Are there pending updates that will make it compatible?
Best Answer10-29-2017 15:42 - edited 10-29-2017 15:44
My blaze isn't working on my OnePlus 2 at all is there anything I can do??
