04-09-2024
00:02
06:42
EstuardoFitbit
04-09-2024
00:02
06:42
EstuardoFitbit
The black clip on which to connect the strap, has broken off, so I cannot attach the strap. Is it possible to mend this. The Fitbit works fine, so I’m reluctant to buy a new one.
Best Answer04-19-2024 12:04
04-19-2024 12:04
If you check on Amazon (US) there is a strap that stretches to fit around the Fitbit that works pretty well. I had the same thing happen and purchased one and I'm pretty happy with it especially considering all the complaints I'm hearing about the 6.
04-09-2024 03:28
04-09-2024 03:28
Hi, @Lizpep something like this might work for your problem. (I haven’t tried it myself, but at least one reviewer mentioned getting this to solve your exact issue.). Might be worth a try, and much cheaper than buying a new Fitbit! My link is for the UK, but you hopefully could find something similar in whichever is your home country.
Good luck, and welcome to the forums!
Best Answer04-09-2024 07:55
04-19-2024 12:04
04-19-2024 12:04
04-21-2024 11:53
04-21-2024 11:53
@mysticrose276 Thanks a lot for sharing your experiences with us.
I believe your recommendation will be incredibly helpful to others facing similar situations. That's why I decided to mark it as the Best Answer.
Thank you again for your willingness to help!
