08-05-2025 06:15
08-05-2025 06:15
Hi Folks,I removed my old Fitbit band and tried to replace it with a new one. The new one won’t attach because there’s still residue from the old band on the clamp. I’ve tried rubbing alcohol, tweezers and even my fingernail, and nothing will remove it so I can’t reattach the new band. Any suggestions please?
08-09-2025 03:36
08-09-2025 03:36
Hi LZeeW
I used all natural nail polish remover on a cotton swab which loosened it. I then was able to remove it with a pair of tweezers.
08-07-2025 13:00
08-07-2025 13:00
Hi @TeacherLaur Can you add a screenshot? This site usually won’t let you include a screenshot with your first post. You should be able to add one now. It might help.
Laurie | Maryland
Best Answer08-09-2025 03:36
08-09-2025 03:36
Hi LZeeW
