09-07-2019
06:42
13:04
09-07-2019
06:42
13:04
Is anyone else having problems with quick view lately? I manually turn this off each night and turn it on in the morning. The last couple of weeks trying to turn it off at night I have had problems. If I try to do it just before bed around 9 or 10 pm it may take 30 - 45 minutes of constantly hitting the sync button to get it to turn off. If I do it around 6 pm, it turns off fine. The home screen in the app refreshes fine, but the behind the scenes sync is not functioning normally.
I have turned bluetooth on & off, tried all day sync on & off, and just cannot find a resolution to this. I think this may have started with the app update.
Last night I kept the quick view off, all day sync on and the quick view did not shut off at all last night and kept waking me up.
09-08-2019 18:23
09-08-2019 18:23
Hi @Greyhoundfun, it's nice to see you again posting here in the Community Forums, welcome back!
I appreciate all the information and details that were shared in your post, thanks for troubleshooting this prior to posting too. To better assist you with this, can you please let me know when was the first time you experienced this and how many times since then? Also, which mobile device you're currently using to sync your Charge 2? Are you using the Fitbit in your non-dominant hand? If you haven't already done so, please try the following steps in the meantime I receive your answers:
Keep me posted and let me know if you have any additional questions.
Best Answer09-08-2019 20:50
09-08-2019 20:50
Ricardo,
Tonight the sync worked fine. However, it has been sporadic when it does not sync so I cannot confirm that this has fixed the entire problem until I can say it has worked for a couple of days in a row.
Today I uninstalled the app, restarted the phone, reinstalled the app and also restarted the charge 2. Since I turn on & off the quick view every day I should know within a couple of days if it continues to sync after going through all those steps.
It has been having issues for 1 to 2 weeks-hard to know exactly when it started since it was sporadic. I can only assume it started after the update since that happened within the last couple of weeks as well. It did happen most days and mostly at night. There were nights when it would not sync at all so the quick view would not shut off. The device is on my dominant hand. My mobile is an LG K20 and has worked with the Charge 2 the entire time I have had it.
I'll post updates over the next couple of days to see what happens.
Thanks.
09-09-2019 08:53
09-09-2019 08:53
I had to hit the sync now button 4 times this morning before it would sync and turn on the quick view. The dashboard refreshed right away and updated the steps, sleep, etc. Any items that require a full sync - quick view, reminders, alarms, notifications - seem to take multiple times before the sync works.
It would be so much better if the quick view could be controlled directly on the Charge 2.
09-11-2019 08:11
09-11-2019 08:11
Ricardo, sync is still not working normally. Sometimes it goes through right away and other times I can continue hitting the sync now for an hour and it will not complete.
09-18-2019 01:06
09-18-2019 01:06
I get exactly this problem with my Samsung Galaxy S10 (and previously with my S9). It started after the App was updated, along with the firmware, I think. Syncing is not updating the Quickview setting. Like the OP, I turn this off at night and on in the morning. Very annoying. I have to do several syncs to make it work. I've uninstalled and reinstalled. Before the App upgrade it worked fine. Also, the 'last sync' time/date doesn't show properly.
