05-24-2022
10:44
14:23
05-24-2022
10:44
14:23
I am not able to read my charge4 when out in day light or when sun is shining. Is there anyway this can be corrected.
05-24-2022 10:43
05-24-2022 10:43
The display on my Charge 4 is impossible to read when outdoors and the sun shines just a little bit.
I have read many other people in this community having the same problem. Some of them got rid of the problem via the ideas/suggestions listed above. But unfortunately not me 😞
What else?
Any suggestions as to how I can solve this issue?
Best regards,
Ivan
05-24-2022 15:30
05-24-2022 15:30
Gosh @ivan8680 I can certainly admire all the troubleshooting and research you did trying to fix your display brightness. I too have noticed an increase in individuals having the same issue. If you have tried all that can possibly be done at this point then I’d call Fitbit Customer Service: https://myhelp.fitbit.com/s/support?language=en_US Maybe they might have a suggestion that has not been discussed/discovered here on the forums.
Best Answer05-24-2022 19:16
05-24-2022 19:16
@SunsetRunner , Nice to see you here. Thank you for the link provided.
@Mckwilson @ivan8680 A warm welcome to the Community! Thank you for your messages and efforts. I merged your threads as it seems that you both have a similar situation.
As our friend MegaBite already did,I would recommend you both to have a chat or call with our team.
They'll be glad to have a closer look at your Charge 4.
See you around.
