01-03-2017
16:56
10:13
01-03-2017
16:56
10:13
My reminders to move have not been working since the latest update. I've tried toggling on and off, disconnecting and reconnecting. Getting a bit frustrated as it's been over 2 weeks now.
04-24-2018 07:27
04-24-2018 07:27
Yikes! .........looks like this fix only lasted a few days.
As of a week ago my Charge 2 is back to only one reminder a day. 😞
05-14-2018 11:14 - edited 05-14-2018 11:48
This feature is still inconsistent for me -- sometimes it works and sometimes it does not. I'm curious to see if people have any work-arounds. Maybe I could setup notifications from another app.
Best Answer05-16-2018 09:02
05-16-2018 09:02
I am no longer getting them either. I have tried resetting my Charge 2 with no success.
Best Answer08-09-2018 14:47
08-09-2018 14:47
If your Charge 2 isn’t reminding you to move, check 2 things: Check your FitBit App to make sure the Reminders to Move is ON; and press and hold the button on the left side of your FitBit device, it will turn Notification ON and/or turn Notification OFF.
Best Answer10-11-2019 15:57
10-11-2019 15:57
Just discovered by holding the side button when on clock screen it turns reminders back on. Mine had quit also and after researching discovered this fix
Best Answer10-11-2019 17:35
10-11-2019 17:35
@xwrdadct that is the way too turn notifications on/off. I wasn't aware that it turned off the notification to move, but it makes sense.
