01-03-2017
16:56
10:13
01-03-2017
16:56
10:13
My reminders to move have not been working since the latest update. I've tried toggling on and off, disconnecting and reconnecting. Getting a bit frustrated as it's been over 2 weeks now.
01-26-2017 20:07
01-26-2017 20:07
support emailed me back and said that their engineers are aware of the problem and are trying to fix it as quickly as possible. we'll see if that actually happens or not
Best Answer01-28-2017 04:24
01-28-2017 04:24
Best Answer01-28-2017 07:16
01-28-2017 07:16
I returned mine last week for this reason. I only bought it for that feature, I already have a Surge. Just came by to see if it was still an issue. Curious to see if the fix
turns out to be hardware or software before I buy it again
Best Answer01-29-2017 15:53
01-29-2017 15:53
Thanks! That fixed the issue for me 🙂
01-30-2017 10:55
01-30-2017 10:55
so far, this is working! Thanks!!!
01-30-2017 10:56
01-30-2017 10:56
could it be that the last update switched it to OFF? It seems like it started happening to a lot of people after the last update.
Best Answer01-30-2017 12:17
01-30-2017 12:17
not for me 😞 tried everything possible.
@catmom6 wrote:could it be that the last update switched it to OFF? It seems like it started happening to a lot of people after the last update.
Best Answer01-31-2017 08:55
01-31-2017 08:55
I tried everything as well. I ended up speaking with support about it and they sent me another watch saying that original fitbit could have been defective.
Everything seemed to be working fine since I got the replacement, but today, I noticed that I had received no reminder and almost missed the hour. Very frustrasting. Hopefully they can give us an update on when this will be fixed because it seems as though it is a software issue rather than a hardware one.
Best Answer01-31-2017 10:03
01-31-2017 10:03
These notifications have stopped working for me since I upgraded the app last night.
Best Answer01-31-2017 12:03
01-31-2017 12:03
Thank you so much! It was just what I need to fix mine! I was ready to sit and cry when my alarms and notifications stopped working, the FAQ's only said to test it by seeing if the vibrational motor went off when I charged it, and it did but charging didn't bring the alarms/reminders back. Now they are back!
01-31-2017 13:46
01-31-2017 13:46
I had this problem as well, was not receiving reminders to move or text messges or calls, until I let my Charge HR 2 battery run all the way out. Once i let the battery completely deplete and the recharged it, it began working again.
Good luck!
01-31-2017 14:18
01-31-2017 14:18
@rubbyrose3 If you are still having trouble with syncing your Charge 2, I'd recommend that you:
2. Reboot your mobile device.
3. Open the Fitbit App to initiate a sync.
@Ohemgee @Noely If you are still not receiving reminders to move on your Charge 2, I'd recommend the tips mentioned below:
1. Double check to make sure that reminders to move is turned on. Click here for instructions on how to check.
2. Verify that your heart rate settings is set to "Auto". Click here for instructions.
3. Follow the tips mentioned here for ways that you can improve the accuracy of your Charge 2's heart rate readings.
Best Answer01-31-2017 21:04
01-31-2017 21:04
Best Answer02-01-2017 04:52
02-01-2017 04:52
My brand new Charge2 (arrived Jan 28th) reminders to move have never worked.
Best Answer02-01-2017 05:39
02-01-2017 05:39
Best Answer02-03-2017 09:37
02-03-2017 09:37
Hold down your power button on the side of the fitbit to make sure your notifications are turned on on the device itself. 🙂
02-03-2017 12:03
02-03-2017 12:03
I have been talking with fitbit the past couple of days. They told me to make sure my notifications were on, I did, I saw they were turned on in the app. I did the reset. Still didn't work.
THEN they had me hold down the side button - not while it was charging as that would reset it - while it is on the main screen (with the time) and when I held that down, it vibrated and said "notifcations off" but then quickly turned to "notifications on".
Now it is working just fine.
Hope this works for you too!
02-03-2017 16:16
02-03-2017 16:16
I'm having the same problem and yes, I did double check the settings. The reminder to move is set to ON.
Best Answer02-03-2017 16:22
02-03-2017 16:22
did you hold down the button on the left side of the tracker? My notifications were set to ON in the software, but when I checked on the tracker itself (by holding down the side button), they were set to OFF. Once I changed that, it worked again.
02-03-2017 16:53
02-03-2017 16:53
