12-21-2016
00:46
07:45
WilsonFitbit
12-21-2016
00:46
07:45
WilsonFitbit
Hi,
I have been struggling to find out what is going on with my fitbit. I recently got it and for the first couple of days it reminded me to move but just stopped reminding me for the past 2 days.
I spoke to the help desk and they suggested I reboot the fitbit and turn the more remind off, but still its not working.
Did anyone have the same problem and is there anyway to get it to work again?
Maybe its faulty and I need to return it to the store?
Thank you
Christine
03-13-2017 10:10
03-13-2017 10:10
04-01-2017 10:06
04-01-2017 10:06
I have had my Charge 2 for several months, and the Move Reminder has worked well. The past few days it has stopped. I have read these column and reset it several times. Turned off the reminder, turned it back on. I have held the button to be sure Notification On. The most frustrating thing is that I have to sit still for an hour not do my 250 steps, and the carefully watch the clock so I know that it is 10 minutes of the hour, and no notification. Big waste of my day.
What else is there to do to make the Move Reminder work?
04-01-2017 11:24
04-01-2017 11:24
If this was a hardware problem, I don't think so, I would say restart the Charge-2 3 times in a row.
Have you tried setting up the reminders to mobe through the web at https://www.fitbit.com/settings then doing a sync through the phone?
I'll assume you have checked that RTMs are enabled.
Some have found that by changing the clock face, some seemingly unrelated none working functions are fixed.
The only other thing I can think of is to do an add device with the replace function. Essentially replacing your Charge-2 with itself.
04-01-2017 14:55
04-01-2017 14:55
Hello Rich -- I was at settings and did set the message. I don't know what "mobe" is. I also do not know what RTM is. Sorry, since it has worked for 3 months, I assume those things are or were set.
Best Answer04-01-2017 15:27
04-01-2017 15:27
Apparently, nothing is working now. Help desk sent this:
I did these:
And now my phone does not find my fitbit tells me no Bluetooth devices found.
I am a technical mess
Now I have no connection.
Best Answer04-01-2017 17:58
04-01-2017 17:58
Best Answer04-03-2017 10:53
04-03-2017 10:53
So simple and it worked! Thanks for posting that solution.
Best Answer04-07-2017 09:30
04-07-2017 09:30
I have the same issue. Trying the reset button and will let you know at 10 minutes before the next hour if it works or not. Was there a recent update? I am also having trouble signing in on my iPhone. It gets hung up and appears to crash. When I tap on Login again, it either freezes or finally goes to my Dashboard.
Best Answer05-18-2017 15:10
05-18-2017 15:10
Have the same problem
Best Answer05-19-2017 05:50
05-19-2017 05:50
Someone else suggested holding the button down on the side to turn notifications on and off. It worked for me.
05-19-2017 05:57
05-19-2017 05:57
Still not working
Best Answer05-19-2017 11:43
05-19-2017 11:43
If notifications are enabled on the tracker itself, then you will need to enable them through the app or website. If theyy are enabled tyere, tyen make a small change and sync. You may always change back later.
Best Answer06-08-2017 10:34
06-08-2017 10:34
I just got my Charge 2 last night and move reminders aren't working. Text notifications worked once when I first got it set up but after that, nothing. In the app everything is set to be on.
Best Answer06-08-2017 12:31
06-08-2017 12:31
I just received a new Charge 2 to replace a Charge HR. I have tried every troubleshooting suggestion noted in the forum threads and none have solved the problem. I've gotten in touch with Customer Service and my case has been escalated to a higher level. I am hopefully it will get sorted and eventually they'll work but I wanted to mention this here since I suspect there are many like me who have (or are considering upgrading) SPECIFICALLY for this reminders to move feature.
Best Answer07-30-2017 02:20
07-30-2017 02:20
Mine had stopped working for over a week. Notifications were showing on on my app but not reminding me! I became really lazy this week, I read your reply, did what you said and bingo! Notifications was off on my watch. So thanks I'll be restarting my 10k walks 😊
Best Answer08-24-2017 12:42
08-24-2017 12:42
My reminders haven't worked for me from the very start. I eventually got it to alert me when my phone rings or receives a text but I'm still not getting move reminders.
Best Answer09-25-2017 07:54
09-25-2017 07:54
This worked for me. I had the phone app with notifications turned on and the reminder for steps turned on with days and times set but holding the button on the actual fitbit to turn notifications back on there was what worked for me. Thank you!
Best Answer10-05-2017 07:12
10-05-2017 07:12
This doesn't work.
Best Answer10-05-2017 07:42
10-05-2017 07:42
Hold the button on the left and on the screen you will see notifications on or off push till it says on
Best Answer11-06-2017 10:06
11-06-2017 10:06
Thank you so much. Mine had also stopped reminding me and this did the trick.
