12-21-2016
00:46
07:45
WilsonFitbit
12-21-2016
00:46
07:45
WilsonFitbit
Hi,
I have been struggling to find out what is going on with my fitbit. I recently got it and for the first couple of days it reminded me to move but just stopped reminding me for the past 2 days.
I spoke to the help desk and they suggested I reboot the fitbit and turn the more remind off, but still its not working.
Did anyone have the same problem and is there anyway to get it to work again?
Maybe its faulty and I need to return it to the store?
Thank you
Christine
12-05-2019 15:51
12-05-2019 15:51
This has worked for me
08-23-2020 00:35
08-23-2020 00:35
have tried this a number of times and still not working. Others at my workplace are having the same problem.
08-31-2020 08:16
08-31-2020 08:16
I am having the same issues with my Charge 3. I, too, have rebooted several times, turned off reminders, notices, turned it all back on, everything without success. I agree it was a bad update. So far, I haven't been able to get the reminders to work at all.
09-20-2020 10:20
09-20-2020 10:20
You've probably fixed this by now, but I noticed that the DND (Do Not Disturb) feature was ported onto the Charge 3 with the last upgrade. This stopped my reminders to move from working because I had it set by accident. Couldn't find any guidance for the Charge 3, but from the Charge 4 manual, it's set when the "no entry" sign is lit. It's off when the icon is unlit (or for some reason, has one "dot" lit at the top after you've left the setting and go back in to check). You get at DND with a long push on the side button.
09-30-2020 19:55
09-30-2020 19:55
Same here -- since they did a firmware update in August. I have tried and retired every suggestion. Today, out of the blue, started getting email on my fitbit from my gmail account and did not ask for this. I think I turned it off but I am getting fed up.
10-12-2020 02:49
10-12-2020 02:49
Thanks so much for this - have been racking my brains to try work this out, I had realised this feature was added but didn't realise I'd turned it on accidentally til I read this!
12-31-2020 16:08
12-31-2020 16:08
Having same problem with charge 3 after working fine fir a year. Grrrrrrrrt
05-22-2021 11:52
05-22-2021 11:52
I'm on my second Fitbit and the reminders never work consistently. Real let down again. Rebooting, turning reminders on and off occasionally work but very quickly stops again. Definitely a Fitbit problem. Perhaps the powers that be should be working on this???? $15 a month in Canada for Fitbit premium and they can't figure this out??? Jokes on me for buying another Fitbit I guess
09-15-2021 03:41
09-15-2021 03:41
Doesn't work... It's such a simple feature, how hard is it to make it work? Last Fitbit device I own.
11-05-2021 16:53
11-05-2021 16:53
I tried everything, and it all didn't work, until I saw your comment Rich_Laue, thank you so much.
I followed tour link https://www.fitbit.com/settings
And turned the reminder to move off and on from there and it worked immediately
11-26-2021 00:32
11-26-2021 00:32
I found a workaround:
Use google assistant and say "Reminder to move in an hour". Be sure sure to have Google enabled to show notification on your fitbit. Once the hour is over, you'll get a notification. You can click it and you'll have a button "1 hour" if you want to move the reminder.
02-01-2022 13:08
02-01-2022 13:08
Mine randomly doesn’t send reminders. Works for a couple of hours and then doesn’t 1 hour, repeatedly. I thought maybe it’s because I hadn’t synced with the app. Nope. Shutdown and soft reboot, nope. Did a full reset back to factory, Nope. Still happens. The closest I’ve come is to do 3 soft reboots in a row. That will work for about 2-3 days then it starts again. No, I don’t have quiet modes or do not disturb enabled either. I was eying the Charge 5, but fell into a 1/2 off deal for the sense that wasn’t applicable to the Charge. Very disappointed.
02-05-2022 02:03
02-05-2022 02:03
Another daily reminder to never buy fitbit ever again.
in 8 month of usage it has constant issues connecting and requires a full reset. Notifications work sometimes only. The app store disappeared. Reminder to move doesn't work. Now it won't even connect.
03-24-2023 07:28
03-24-2023 07:28
My reminders to move turns off right away by itself each time I turn it on. It shows as on in the time to get moving tile, but keeps turning off under the daily activity settings in activity and wellness. I’ve tried everything suggested more than once and it’s still not working.
Having these reminders is an important part of my daily routine. Please help!
04-06-2023 15:29
04-06-2023 15:29
Exactly the same issue here, ‘reminders to move’ turns off in the app immediately after I click out of that page. It’s so annoying, I miss having the reminders but can’t fathom out why it’s defaulting to off!
