12-04-2018
10:41
18:22
12-04-2018
10:41
18:22
I recieved my replacement Charge 2 and my LGv30 will not pair with it. My old charge 2 pairs just fine. My boyfriends phone sees the replacement charge 2 in Bluetooth ( unless its seeing my old charge 2? Not sure it can if it's paired to my phone.) updating my phone, rebooting ( many times in between troubleshooting) I have turned off/ Bluetooth , unpaired/deleted old charge, tried to replace old charge with new charge, uninstalled fitbit app, reinstalled app, tried hard restarting new charge but it just shows the setup screen fitbit.com/setup the only thing I haven't tried is logging out of fitbit then back in ( that I know of). I contacted support and they gave me a return label and recommended sending back for a second replacement. I don't really want to wait another 2 weeks . 😭 I don't see why the new one won't pair with my phone while the old one pairs just fine.
Moderator edit: format
01-14-2019 03:14
01-14-2019 03:14
I assume the number displayed when you power up is the firmware version. The firmware version on my replacement is 22.53.04. Doesn't pair.
Anyone else?
01-14-2019 03:23
01-14-2019 03:23
https://www.facebook.com/FitbitUKIreland/posts/2414802351925722?comment_id=2416762058396418¬if_id... Their UK Facebook page with the same problem.
01-14-2019 04:07
01-14-2019 04:07
So the one they’ve sent me that finally works (3rd attempt) is 22.55.2
So they obviously have access to some that aren’t affected. That’s the number you need to insist they send you.
Best Answer01-14-2019 05:31
01-14-2019 05:31
chatting to support now.
Replacement Charge 2 pebble won't pair.
So i have to send it back.
My band has broken so they're sending me a new one.
So i get a whole charge 2 in 2 pieces. Of which 1 won't work, yet they can't send me a whole new charge 2.
It is insane
Best Answer01-14-2019 05:49
01-14-2019 05:49
Mine is 22.53.04 Does not work.
Best Answer01-14-2019 05:51
01-14-2019 05:51
Does @AlvaroFitbit have any comment on any of this?
Best Answer01-14-2019 05:57
01-14-2019 05:57
their "team" is working on fixing the bug in the app.
At least that's what they say.
So we will have to wait until they do just that.
Although this problem has been around for at least a month now.
So i don't have hope for a quick solution
Best Answer01-14-2019 06:15
01-14-2019 06:15
Best Answer01-14-2019 06:39
01-14-2019 06:39
@Ellie163 I can't see what you wrote
Best Answer01-14-2019 06:41
01-14-2019 06:41
Best Answer01-14-2019 06:43
01-14-2019 06:43
yup. They even suggested me keeping this pebble and waiting for the bug fix to the app.
Best Answer01-14-2019 07:11
01-14-2019 07:11
Yes. Same here - 22.53.04. It will not pair. (I don't remember what the versions were on the previous two that also would not pair, but I think it was the same.)
Best Answer01-14-2019 07:20
01-14-2019 07:20
@Nagswoman wrote:
22 53 04
I meant the FW version of the device that worked. In your previous post you mentioned it is not 22 53 04
01-14-2019 07:23
01-14-2019 07:23
I think that sent in error. It wasn’t intended to be a message.
Best Answer01-14-2019 07:47
01-14-2019 07:47
Yes it would be good if admin could comment on this.
Best Answer01-14-2019 07:52
01-14-2019 07:52
@CJLoc wrote:Does @AlvaroFitbit have any comment on any of this?
What i've seen in the past few weeks is that the moderators won't respond in the threads discussing the useless replacements. I saw only maybe 2 responses where they advised people to waste their time by attempting numerous steps when it was clear they've received a replacement. I confronted one of them about it and got no response (as expected).
It seems Fitbit are hiding because they don't have a solution (I doubt they are able to easily update the FW version of the replacement batch device (if it's even a FW issue, might as well be HW) and that's why they are stalling). Even with such an obvious hardware or firmware problem, they still claim it's an app issue and send generic responses asking to be patient.
I've been researching what my rights are in this case but haven't found explicitly defined time periods yet. However I would suggest everyone to contact their local consumer rights organisations - that's what i'll be doing very soon.
The fact they've already sent a replacement means they have acknowledged a problem with the original device and HAVE to provide either a refund or a working replacement. I also believe they have to extend the guarantee/warranty for each customer with the period of time it took to resolve the problem.
My patience is running out mostly because I keep reading comments from people who are getting replacement after replacement without being notified about the problems even now. To me this means they're testing how far they can go keeping people in the dark until they give up probably. There's no honesty here.
01-14-2019 08:27
01-14-2019 08:27
01-14-2019 08:51
01-14-2019 08:51
01-14-2019 10:21
01-14-2019 10:21
I emailed the top executives and got a prompt reply. I am being mailed a retail packaged new device. They said this will remedy the problem. We shall see...
01-14-2019 10:29
01-14-2019 10:29
Via what email? All I keep getting to to do is send in my replacment for another replacment
