11-30-2021
13:09
10:32
AndreaFitbit
11-30-2021
13:09
10:32
AndreaFitbit
Hello, my Charge 3 (not the special edition with Fitbit Pay version) which I got in late 2018 or early 2019 is starting to act up. Even when the battery is at 100% the display which I've set to "Normal" for the brightness is acting like it's set to "Dim" and when "Dim" is selected, it's impossible to see! Also, the battery isn't holding the charge as long as it used to (rebooting doesn't help).
I'm not sure if I should get the Charge 5 or the Versa 3. What you you recommend?
11-30-2021 13:33
11-30-2021 13:33
Hi @robman501a there is a quiz designed to help us find the right device - click to take it
11-30-2021 16:18
11-30-2021 16:18
Thanks!
Well, since I go to the gym everyday and do lots of cardio and strength training, I do want to be notified when my heart rate gets too high. So according to the quiz I should get the Charge 5. I really don't need the voice features or music access and it almost seems it's suggesting the Sense over the Versa 3. I guess that makes sense (since the sense is newer) haha.
12-01-2021 08:31
12-01-2021 08:31
the new charges have extra stuff as well, instead of having Active Minutes you now have Active Zone Minutes.
https://help.fitbit.com/articles/en_US/Help_article/1379.htm
12-01-2021 14:07
12-01-2021 14:07
I'm now seeing on my Charge 3 that the edges of the display is starting to fade and it's brighter in the center. I guess these are all signs of failure due to age?
12-04-2021 10:59
12-04-2021 10:59
Thanks for getting back to us and for sharing your Charge 3 replacement inquiry @robman501a. I appreciate your comments and advise @Odyssey13 and @temporaldoom.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Keep on visiting the forums.
