05-08-2022 16:31
05-08-2022 16:31
My C3 has black screen that I've not been able to fix. I want to trade it in and get a new device. How can I reset my device from the app only? If I could see the screen I know I could reset it on the device but that's not an option.
05-08-2022 17:39
05-08-2022 17:39
Welcome to the Fitbit Community, @SprGPa.
I'm sorry to hear about the difficulties you experienced with your Fitbit Charge 3. Thank you for the information provided.
In this case, I would recommend restarting your Tracker. In addition, you can perform a long restart:
In addition, you can try to change the clock face:
Hope this helps.
19:00
19:05
EdsonFitbit
05-08-2022
19:00
19:05
EdsonFitbit
I've tried all of these, multiple times. I've given up and just want to clear the data so I can get rid of it. I need to to this on the app because the screen is black.
Moderator edit: all-caps
Best Answer05-08-2022 19:14
05-08-2022 19:14
Thanks for your response, @SprGPa.
The instructions shared above have been useful for other Fitbit users experiencing a similar situation.
There is no option to reset your Fitbit Charge 3 from the app only. In this case, you can remove your Charge 3 from your account by following the instructions in this article in the menu "How do I remove a Fitbit device from my account?".
If you want to delete your Fitbit account, please follow these steps.
Have a nice day.
Best Answer05-08-2022 19:57
05-08-2022 19:57
I tried all this but it dosen't work as I press the button but it continuously vibrates and the screen is black, when I take it off the charger even after charging for half an hour and see if there is a response, nothing happens.
Please help!
