Running steps vary by day with charge 2
Every day I run the same route yet end up with varying step counts.  Usually between 4300 to 4700 for a 3 mile route. I have adjusted the stride length but realize that really only improves the distance/mile accuracy.  Also, have rebooted many times.
I realize that for 3 miles that it will not reflect 6000/2000 per mile steps  but it should be at least 5000 steps and if not that, at least consistent step count for running the same route every day.  Any suggestions?
4 REPLIES 4
Are you relying on auto-recognize?  If so, check if it is including the whole time interval.  If not try using the Exercise app.  See
How do I track my workouts with my Fitbit device?
JohnnyRow, not using auto recognize.
How do I find the exercise app you reference on a charge 2?
Did you look at the link I gave?  It tells how to use the Exercise App.
If you are not using that, I expect you are using auto-recognize - that means Fitbit recognizes that you are running and calls it a workout and gives some stats for that workout, including steps.  If not getting that, how are you determining number of steps?
JohnnyRow, thanks, found the exercise app.
Now, can youy help in turning on auto recognize for a charge 2?  Thanks.
