01-25-2018
16:44
18:54
01-25-2018
16:44
18:54
I was trying to figure out how to get my Charge 2 to show my phone calls and text when it's close to my phone. Is this possible? If so how do I go about doing this?
01-26-2018 04:14 - edited 11-17-2023 04:34
It's great to have a new member around, welcome @Meg2517! Do you have the Galaxy Note 5 or the S5? Just clarifying due to the Galaxy S5 is not compatible with the Fitbit app, therefore, the tracker won't work with your mobile phone. Check the list of our supported devices by clicking here.
In order to enable notifications on the Charge 2, confirm or adjust these settings:
Set up the notifications you want to receive on your wrist. Make sure your charged Fitbit device is nearby.
Charge 2, has a Notification setting on the device. To verify that it's on, while on the clock screen, press and hold the button. Notifications should appear on your device when it's near your phone (about 30 feet).
Let me know if there's something else I can assist you with.
Best Answer01-02-2020 18:30
01-02-2020 18:30
what fitbit is compatibility with the Samsung S5??
03-18-2022 15:16
03-18-2022 15:16
That the fitbit app is not compatible with S5 is stupid. There is no technical reason it shouldn't be.
09-19-2022 07:21
09-19-2022 07:21
So true. I'm regretting my purchase of versa 2. The shop assistant said it was an older version of fitbit and so would work fine with S5. It's able to be paired with my work phone (iPhone 11) but iPhone is horrid and I'd rather use my android for personal use so I have compatability with Google.
Unfortunately, I scratched the screen on the first day before I even tried to set it up, so I'm stuck with it.
