10-12-2016
10:11
10:26
10-12-2016
10:11
10:26
12-01-2017 04:31
12-01-2017 04:31
Toothpaste didn't work for me.
Try Polywatch (designed for this type of screen) or autosol
12-09-2017 16:48
12-09-2017 16:48
My puppy just stole my fitbit and put a little but annoying tooth mark on my screen. Why O Why the screen. They have replacement bands, but can't find out about replacement screens anywhere. Also I didn't get the warranty, haven't decided if that was a good or bad idea...
12-09-2017 17:11
12-09-2017 17:11
Well @MumB Fitbit does have 1 or 2 year warranty depending on the country it was purchased for.
In your case the extended wsrsnty would have been good since it covers physical damage.
12-10-2017 10:00
12-10-2017 10:00
Is it possible to replace front bezel of Fitbit charge?
01-02-2018 10:25
01-02-2018 10:25
Toothpaste didn’t remove any scratche on my Charge 2
01-14-2018 05:01
01-14-2018 05:01
Personally I think that we should be able too repair our fitbits because just daily activities and my is badly scratched, I've only had it a month. Also we should be able to repair it seems as though we use it for exercise and of course we may trip or fall. I think that screen protectors shouldve come with our Fitbit because they are essential seeing how many at each damaged so easily.☹️
01-15-2018 11:08
01-15-2018 11:08
You can remove scratches like this
01-15-2018 13:18
01-15-2018 13:18
Thank you for this advice I will try this because the scratches are really bothering me i will put on if it works or not hopefully it does🤞🏻🤞🏻
01-15-2018 13:35
01-15-2018 13:35
01-26-2018 01:50
01-26-2018 01:50
Toothpaste doesn't work.
try any of the products I mentioned. Polywatch is best or autosol (cheaper)
01-26-2018 02:06
01-26-2018 02:06
Doesn't work. Use my method instead!
01-26-2018 07:37
01-26-2018 07:37
What is your method?
04-20-2018 11:37
04-20-2018 11:37
Bands cost $6.97 at Walmart for charge 2
05-18-2018 14:58
05-18-2018 14:58
I think I found the remedy for scratched Fitbit screens. I rubbed a very fine glass stove top cleaner into the surface to remove most of the deep scratches. Anything really fine like that should work, just be careful. That will leave the crystal dull looking but "ok. Then I ordered the 6 pack of IQ Shields for Charge 2 on Amazon for $6.95. Applied the plastic shield and it looks as good as new. Nice and shining. We'll see how long it last, but it looks good for now.
Good Luck
05-18-2018 16:56
05-18-2018 16:56
05-18-2018 20:37
05-18-2018 20:37
05-27-2018 12:31
05-27-2018 12:31
Wal-Mart has bands for that work for fitbit. I bought one for mine. Not too pricey either. Or Amazon.
06-06-2018 09:04
06-06-2018 09:04
Beware cheap imitation bands - I nearly lost my Fitbit because they can come unclipped unexpectedly!!!
06-11-2018 08:06
06-11-2018 08:06
Unfortunately, acrylic/plastic is not scratch proof. Gorilla glass is the same. Once you have a scratch you are stuck with it. Luckily, with the Charge 2 it can be polished out really easy, and in a few mins the screen is back to normal.
Any plastic/acrylic scratch remover should work.
Here is my thread about it: How to fix scratches on charge 2
I used Autosol (metal) but any of these should work fine. Polywatch is recommended.
Halfords - Fenwick plastic/acrylic scratch remover (not used but cheap)
Autosol - soft and hard plastic remover (I used the metal one which was great, this may be even better)
Watch Face restorer (not used)
Polywatch (not used but friends with acrylic/plastic watch faces swear by this stuff)
Here is a review, before and after using Polywatch on a Charge 2, looks like it works great!
06-11-2018 08:08
06-11-2018 08:08
